Gentlemen couple questions for you. Please. KB 2.6, 8.5psi with KB factory tune. Stock TB.
Was watching IATs today. 75 degrees ambient temp and sunny. After getting warmed up fully from cruising they were around 125-130 at idle. While driving at 45mph they did not seem to go down much and still hovered around the 122-128 degree mark. There is plenty of fluid (70/30 mix w/WW) in the intercooler and the pump is working fine. So not sure why they don't fall much when the car is in motion. I went WOT, 1st-3rd gear, and they did climb some but not that much. I let off at 90 and the values were still under 140. I am assuming this is OK but just looking for some reassurance. Per the boost gauge the car is seeing the proper pressure when WOT.
I noticed I was unable to get the car to spin from a roll in 1st with the goodyear f1s today. I was surprised. It seems like these relocation brackets made a huge difference with traction. But doubts persist and I wonder if something could be wrong, like it is pulling timing. I have an aeroforce interceptor gauge and it can monitor Spark Retard and Ignition Advance. Which of those values should I be watching to tell if it is pulling timing and what values should I be expecting?
TIA
TIA
