hammerdown
Frequent lurker here, but I seldom post. Couldn't find an answer to this using the search function so here goes:
I've lost the only keys to my Mustang (well technically I didn't loose them but that's neither here nor there at this point) and am having new keys ordered from Ford. The dealership is going to have to re-program the PATS (Passive Anti Theft System) in the ECU in order for the car to accept new transponder keys.
I'm a little concerned because my car is supercharged and has a custom tune. Can anyone tell me if/when the dealership re-flashes the ECU to reset the PATS system is it a complete reprogramming that will overwrite the current tune with a new factory fresh one or will it simply address the PATS section and leave everything else alone?
I read up on the procedure in the shop manual and it seems as though the whole thing is done with the Ford/Rotunda VCM/IDS scan tool and only interacts with PATS during the reprogram but I don't know this for certain.
This is how the procedure goes as far as I can tell:
http://iihs.net/fsm/?dir=413&viewfile=Key Programming Using Diagnostic Equipment.pdf
Suppose it's not too much just to ask the service writer but half the time I seem to know more about my car then they do so I'm a little skeptical taking anything they say at face value.
This place being hands down the best tech-oriented forum I've found around; I figured if anyone had the real answer, I'd find it here.
Thanks,
-HD
Thanks,
-HD
! And save literally $2-300.00.
