captdistraction
Corner Carver
Pictures of all parts at http://www.chris-wynne.com/coyote . I know I need pictures with my name in all of them, but if possible I can do on a as-requested basis (othewise mods please PM me so I can copy prior to thread delete). Parts in Phoenix Arizona, asking plus shipping on all:
Coyote Engine: (price is for all qty total, not per unit) 36k miles unless otherwise noted. Condition excellent unless otherwise noted.
Coyote Intake manifold $100
Coyote intake track $50
injectors 8 $100
Coyote Block, Damaged (overbore possible) 1 $300
Coyote Crank, Forged 1 $150
Coyote Heads, Damaged 1 $200
Intake Cams 2 $100
Exhaust Cams 2 $100
Rocker adjusters 32 $20
Oil Pump 1 $25
Oil Pan, Windage Tray, Pickup Tube, level tube and stick 1 $75
Oil Filter Adapter 1 $20
Exhaust Manifolds 1 $75
Head Sensors 4 $40
VCT hardware (Intake) 2 $50
VCT hardware (exhaust) 2 $50
Timing Cover 1 $100
knock sensors 2 $20
Timing Chains, guides, tensioners 4 $40
Water pump 1 $40
Balancer/Damper 1 $50
$1750 total above
Broken Coyote Engine (all remaining above) 1 $1000
Pictures:
injectors 8 $100
Intake Cams 2 $100
Exhaust Cams 2 $100
Oil Pump 1 $25
Head Sensors 4 $40
Timing Cover 1 $100
knock sensors 2 $20
Water pump 1 $40
$1750 total above
Pictures:
