This upgraded GT500 hat will support 750-800rwhp without a bap. It's a direct drop in replacement for your oem gt500 hat. The Gt500 hat itself is a new takeoff and in excellent shape, the hat is modified by me with two lethal divsionx 340lph pumps and walbro filter socks. The pumps are lighly used with just dyno time and a few track passes. I deleted all the factory lines and oem T fitting and replaced them with larger 3/8" gates submersible lines and a higher flowing 3/8" Y fitting all held together by ss fuel hose clamps. Also installed 10 gauge wire terminals to each pump and installed my pprv delete kit, it has an 05-09 level sender on it as well.
This hat is ready rock and make big power!
Info on the pumps.
http://www.lethalperformance.com/divisionx-stryker-340lph-fuel-pump.html
*Requires the gt500 fuel system dual fpdm harness not included.
**I offer a $150 core refund if you send me back your stock gt500 hat.
$399 Free shipping!
Info on the pumps.
$399 Free shipping!
