What do you want to talk about??????????? Or are you just looking to have a battle?
What is "techy" about arguing 20% vs 40%? And I'm always amazed how folks get pissed off when a sponsor has to balls to mention something that he has *when it's actually helpful* to someone. I bet you mentioned your car shifted better with your changes, I bet you did it here in fact, right? But if I do it, well there must be trouble brewing!
Here's the thing, I belong to this forum just like you do. I have a 2011 just like you do. I'm a car guy, just like most here. I happen to run a business, so all that gets ignored as if none of the other stuff applies.
If you want to start your own thread please be my guest. Opinions make the world go 'round.
And if you want some more "tech".... ok:
MTL has friction modifiers specifically to help synchro engagement. Redline is fully synthetic, not a petroleum basestock with a lot of additives tossed in, enough to be called "synthetic". That helps the car shift better.
The stock shifter has a small, thin, and weak baseplate that allows flex when banging gears. The Steeda Tri-Ax uses a much thicker billet plate that keeps everything more lined up. Also it has better centering springs, and doesn't use a plastic lock-out for reverse
The stock shifter bushing is, as most know, really soft rubber in a stamped piece of flimsy metal which allows the tailshaft of the trans to move all over the place. And that in turn moves your shifter too. The Shifter base bushings keep the transmission much better located and shifting is easier when the gears are where you expect them to be.
Is that more detailed than Joe-Bob Brown saying "hey that works better"?
