Throw Out Bearing Question
yukonblizzard
I am right in the middle of installing a manual transmission (tr-3650).
My question is should the throw out bearing be touching the 'teeth' of the pressure plate? Because it is now and I cant seem to get it close enough to the engine to bolt the tranny on. I have searched to no avail but have had no luck.
Thanks
NjsGT
Back in the game....
NJ
Yea, its supposed to be touching at all times, thats why it has bearings to spin....... Maybe you dont have the teeth on the input shft lined up with the clutch teeth?
702GT
S197 Fanatic
Las Vegas
Definately check your clutch alignment. Maybe double check the part number on the slave to be sure it's for the correct application. I think the 6060's are different length than the 3650's.
yukonblizzard
Thanks guys, I figured it out. The input shaft wasn't lined up with the clutch teeth like NJsGT said. I had to jiggle it around for a while to get it to go.
NjsGT
NJ
Ya sometimes you just gotta get alittle rough with it to get the teeth to align.. Glad you got it. Now on to the fun part..... bleeding the slave line :naughty1:
