Ring and Pinion?
tjm73
of Omicron Persei 8
Rush, NY
Has anyone swapped their R&P? to what? and what did it do to your E.T. and mpg's?
Lots of data on the V8's for this swap, not so much for the V6.....
timfoster405
Maryland
Almost all v6's come with 2.73s although mine came equipped with the 3.31's as an option. I will run mine soon and let you know what I get...
Vapour Trails
The Renaissance Man
Winnipeg, MB, Canada
Why would it be any different? More gear = more torque multiplication = moar faster. MPG will generally be reduced slightly.
tjm73
of Omicron Persei 8
Rush, NY
I would of course expect to see the same trend in effect with such a change, but I am curious about real world results.
In real world results I've found that most vehicles generally come with too tall of a gear in the rear end. It might make for a slightly higher number on the government highway MPG test but in real life your motor is struggling trying to move, so you have to use more pedal all the time. By going to a shorter gear (higher numerically) your vehicle can accelerate easier with less pedal. If you drive 50K highway miles per year on cruise control then you pay prefer the taller gears, but the rest of us get as good or better mileage with shorter gears. My Bullitt comes with 3.73's and I still have enough gear to run 60 at 2000rpm so the motor isn't working very hard or burning a lot of fuel at cruising speeds. With the taller gears I'm sure that 5th gear is pretty much worthless to you.
ant speed
dallas area
I swapped my 2.73 for 3.55 and definitely no complaints here and after i quit mrssing around gas mileage barely took a hit. Still get about 22/30
on3uluz
Just swapped 4.10s jlt race red cold air and revolution tune on the gf,s 2013 runs like a champ car went 14.52 stock auto in 100+ degree weather adam( owner of revolution) still working out transmission bugs but looking for lower 13s
on3uluz
Gassilliage improved around town at 60 im aroumd 2100 rpm
