Who thinks I'll break 12's n/a and 11's on spray?
silver rhyno
drop sway bar..but no other weight reduction..not sure about the DA i didnt check it..these numbers are from last saturday and there was a 10mph head wind
Blackbird1084
Something is wrong with the top link? What track do you race at? I'm just trying to gather all the info I can so I can be safe on my setup and know what to expect.
Blackbird1084
That's pretty good. Your da's that day were 949 around the time of your run. That's damn good air.
silver rhyno
humidity is the major problem around here but its still early in the season..i think i can get another tenth before the weather goes bad...like i said there was a 10mph head wind that day and my slicks was brand new..once i get them broke in and get a little more aggresive with the launch i should have it..
Blackbird1084
Hey rhyno you said you had a weak bottle. What did you mean? Low psi or low nitrous in the bottle. A zex kit is pretty much useless below 750 psi. I haven't had a chance to run this year with as much psi as I want (1025-1050). But I hope to change that this weekend if I dont work. I'll be testing with zex's 150 jets (67n/38f).
silver rhyno
low nitrous..i had 950psi...but the bottle had 3 or 4 75 shot passes...so when i ran the 125 shot the bottle im sure was less than half full..just so you know we weighed a new bottle then made a dyno pull with the 125 jets the re-weighed the bottle 2 lbs loss..so if your goin to run 150 shot you might get 3 passes out of it..i would bring extra bottles..
Blackbird1084
Actually it would have had over 6lbs left in it. I have ran over 12 passes on one bottle on a 75 shot. I usually get 9 1/2-10 passes on zex's 125 shot using a standard 10lb bottle.
Blackbird1084
A dyno run is usually longer than a pass at the track depending on the car. I ran zex's 150 jets while dataloging/tuning and made about 7 full pulls from 1st to 120mph in fourth.
silver rhyno
12 passes on a 75 shot then almost 10 on a 125shot thats almost double the nitrous and your only losses 2 passes on a bottle...do you see whats wrong with this?
Blackbird1084
I know it looks messed up. But I've got 12 slips from the same day on the 75 shot and I only have one bottle. Plus look at what I said about running the 150 jets. I'm getting just slightly over half the pulls that I was on the 75. Plus I don't have a heater yet. The more pressure your system has the more nitrous you use during a pull. As bottle pressure drops the less you use. On the 75 shot I made more back to back runs than with the 125 as I allowed for cool down time to check plugs with the 125. The bottle would be down to 750psi during the last 1-2 runs on the 125 shot. Those runs are always the slowest of the day. The fastest I have gone through a bottle was 8 pulls with the pressure steady at 1075 down to 1025 during a hot day.
