Dual GT500 fuel pump and wire kits
JeremyH
3V Fuel Guru
Virginia Beach
Alright guys only got this one setup and when it's gone, it's gone!
First come first serve!
GT fuel hat with two brand new GT500 fuel pumps installed. Hat includes a 05-09 level sender, upgrade to larger 3/8" hose and y fitting and larger 10 gauge wiring and terminals to each pump. Also comes with my fuel sytem wire upgrade kit to the fpdm and my 10 gauge fuel hat upgrade harness. This setup will support around 650rwhp depending on injectors size. This hat is a drop in replacement and comes with instructions for an easy install on the wire kits.
$349 Free Shipping! :beer:
JeremyH
3V Fuel Guru
Virginia Beach
Looks like it to me, but just to be sure...
Single FPDM?
Yes sir the single fpdm, its rated to 30amps and can easily handle these 2 pumps. I personaly made 650rwhp with 2 ford gt supercar pumps on the single stock fpdm in this configuration. With the two wire upgrades these gt500 pumps pull around 8-10 amps a piece and the duty cycle drops 15% over the stock wiring. This setup will out flow the the ford dual fpdm gt500 hat setup because of the 10 gauge wire upgrades, larger 3/8" fuel hose and high flow Y fitting vice the the 5/16" T fitting on the stock gt500 fuel hat. :beerdrink:
