Not sure if this has been mentioned anywhere on the site.....Recall on select Automatic 2012-2013's for failure to illuminate back up lights when trans is placed in reverse...
Make: FORD Model: MUSTANG Model Year: 2012 Manufacturer: FORD MOTOR COMPANY Report Receipt Date: MAY 03, 2012 NHTSA CAMPAIGN ID Number: 12V190000 NHTSA Action Number: N/A Component: POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Summary:
FORD IS RECALLING CERTAIN MODEL YEAR 2011-2012 FORD F-150, 2012 EXPEDITION AND LINCOLN NAVIGATOR, AND 2012-2013 MUSTANG VEHICLES, FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NOS. 102, "TRANSMISSION SHIFT LEVER SEQUENCE, STARTER INTERLOCK, AND TRANSMISSION BRAKING EFFECT" AND 108 “LAMPS, REFLECTIVE DEVICES AND ASSOCIATED EQUIPMENT.” THESE VEHICLES MAY HAVE A TRANSMISSION RANGE SENSOR (TRS) THAT WAS CALIBRATED OUT OF SPECIFICATION FOR REVERSE GEAR. Consequence:
IF THIS CONDITION EXISTS, THE TRANSMISSION MAY NOT GO INTO REVERSE OR WHEN THE DRIVER PUSHES THE SHIFT LEVER IN THE REVERSE “R” POSITION AND THE VEHICLE’S TRANSMISSION DOES GO IN REVERSE, THE “R” MAY NOT ILLUMINATE ON THE DASHBOARD OF THE F-150, EXPEDITION, OR NAVIGATOR MODELS AND/OR THE BACKUP LAMP ON THE REAR OF THE F-150, EXPEDITION, NAVIGATOR, OR MUSTANG VEHICLES MAY NOT ILLUMINATE. THESE CONDITIONS INCREASE THE RISK OF A CRASH OR A PEDESTRIAN BEING STRUCK DUE TO THE VEHICLE’S NOT SIGNALING IT IS IN REVERSE.
