2011 TSB Thread
S197 in SC
when you can format your email address for me I'll send you the TSB
I'm not in the habit of posting my email address on a public forum. I posted it that way so that someone cannot search my personal address. Sorry if you thought I was being funny. I thought you would be able to understand it. I'll pm it to you.
Atlanta GA
This isn't craigslist... Mine is [email protected]...........
GeorgeInNePa
Clarks Summit, PA
Does anyone know why, on the TSB 11-11-11, they list 4 part numbers for the solenoids, but only talk about replacing 3 solenoids?
"2. Replace the three (3) normally high solenoids.
Line pressure control (LPC), C35R Direct
Clutch (SSB) and the C456 Overdrive-Low
Reverse (SSD) solenoids. Refer to WSM,
Section 307-01B."
"AL3Z-7G383-K Shift Solenoid (Band 2)
AL3Z-7G383-L Shift Solenoid (Band 3)
AL3Z-7G383-M Shift Solenoid (Band 4)
AL3Z-7G383-N Shift Solenoid (Band 5)"
http://www.tunelogic.net/tsb11-11-11.pdf
Bmr4life
2005 GT
Atlanta
Section 307-01B."
You plan on doing the replacement yourself?
Bmr4life
2005 GT
Atlanta
Yes. It looks like it's a pretty straight forward job.
Drop the pan and filter, drop the "valve body", remove old solenoids, insert new solenoids, and then reinstall the parts.
I was considering the same. Either I do it myself or I go through the trouble of returning to stock and let them do it. Would I have to deal with transfluid doing it myself?
GeorgeInNePa
Clarks Summit, PA
Ok, I just had my question answered on another site.
I'll post it here for anyone else that didn't understand the TSB (like me).
There are 4 different "band" numbers on the solenoids. You need to replace the three mentioned in the TSB, but you could have any combination of those four different solenoids, including having 2 or more of the same "band" in your Main Control (valve body).
The Pro Tip is to drop the pan and MC, then remove the three solenoids that need replacing and get the band numbers off them. The new solenoids need to go back into the same holes the old ones came out of. Don't mix the bands...
Yes, the car will be laid up for a while if you don't have a box of them on the shelf or if your local dealer doesn't have them in stock.
Thanks to Chuck@Evolution for answering this for me on another board! ;)
hawkeye18
omgwtfbbq
So there are March cars, thanks. I didn't think they had any until April.
My '12 was built on February 4th, 2011. It was one of the first down the line. I called Ford and best they can figure it was in the first 50. I don't know of anybody that's taken delivery of theirs before me, either! (date in sig)
I am happy about 11-10-17 as my GT does this something fierce. It's pretty embarrassing driving around in multi-level parking lots as it goes GRONK every time I hit an incline or decline, and every. single. speed. bump.
hawkeye18
omgwtfbbq
As a follow-up, I had TSB 11-07-08 performed (gronky front control arms), and had both arms replaced under warranty.
The noise is GONE! For now. We'll see how they fare down the road.
FYI, Freedom Ford in Norfolk is who did the work. Somewhat impersonal, but otherwise great service.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
5.0L ENGINE - METALLIC RATTLE OR SCRATCHING TYPE NOISE FROM FRONT OF LEFT HAND CYLINDER HEAD AT IDLE - BUILT ON OR BEFORE 3/31/2011
FORD:
2011 Mustang
2012 Mustang
2011 F-150
ISSUE:
Some 2011 F-150 and 2011-2012 Mustang vehicles (excluding Boss) built on or before 3/31/2011 and equipped with a 5.0L engine may exhibit an intermittent metallic rattle or scratching type noise in the area at the front of the left hand (driver side) cylinder head at idle with the engine at operating temperature.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
NOTE: NOISE IS NOT A TYPICAL UPPER ENGINE TICK OR TAPPING NOISE.
  1. With the vehicle in park, start the engine and operate at idle allowing the engine to warm to normal operating temperature.
  2. Using a mechanic's stethoscope or EngineEAR, evaluate area at front of left hand (driver side) cylinder head for metallic rattle or scratching type noise. Stethoscope or EngineEAR probe should be placed in the areas shown. (Figures 1 and 2)
  3. Is the noise heard in the areas shown? (Figures 1 and 2)
    Figure 1 - Article 11-9-15
    Figure 2 - Article 11-9-15
    (Place stethoscope on cylinder head oil galley.)
    1. Yes - Replace the left hand primary tensioner and the left hand timing chain tensioner arm using the kit part number provided in this article. Refer to Workshop Manual (WSM), Section 303-01C, Camshaft-Left Hand , for removal and installation procedure.
    2. No - Do not continue with this article. Perform normal diagnostics. Refer to WSM, Section 303-00.
      NOTE:FAILURE TO REPLACE BOTH THE PRIMARY TENSIONER AND TIMING CHAIN TENSIONER ARM MAY RESULT IN OVERLOADING OF THE TIMING CHAIN AND UNDER CERTAIN CONDITIONS COULD LEAD TO TIMING CHAIN FAILURE.
PART NUMBER PART NAME
BR3Z-6L266-AA Chain Tensioner Kit
ZC-30 Motorcraft® Silicone Gasket Remover
ZC-31-A Motorcraft® Metal Surface Prep
TA-30 Motorcraft® Silicone Gasket and Sealant
BR3Z-8255-A Thermostat Seal
F1VY-8507-A Water Pump Gasket
BR3Z-6A340-A Crankshaft Bolt
BR3Z-6020-B Front Cover Gasket Left
BR3Z-6020-C Front Cover Gasket Center
BR3Z-6020-D Front Cover Gasket Right
BR3Z-6584-A Left Hand Valve Cover Gasket
BR3Z-6584-D Right Hand Valve Cover Gasket
BR3Z-8620-AA/C Stretchy Belt
I'm taking my car in on Tuesday for this exact issue. I will post up my experiences. This appears to be quite an involved repair...
Sent from my toilet using Tapatalk.
tmcolegr
It's All About the Build
Central, FL
Tsb 12-06-11
Clutch pedal squeak or creak noise
  • tsb12-06-11.pdf
Sky Render
NW of Baltimore, MD
So the dealer couldn't get my car to make the noise. It seems to come and go, so I guess I'm just going to wait until it either does it all the time or the motor blows up. Whatever, I still have 40K left on my warranty.
:nah:
tmcolegr
Central, FL
Sync - various functionality concerns
TSB 12-7-6
  • tsb12-07-06.pdf
MUSTANG GUY
I have the 2011-2012 rear brake squeal on my car and would like to do the TSB myself instead of letting the dealership doing it.
Does anyone have a how-to with pics on how to replace the updated caliper clips?
2011mustanggt
Is there a master list with links to all of the TSB'S???
SOmeone must be compiling a master list, yes? PLease share!
Thanks!
tmcolegr
Central, FL
TSB 12-8-15
Rear drive axle vent - oil leak
  • tsb12-08-15.pdf
