Snow Methanol injection kit installed.. question
JA BoostedSTANG
Jax FL
I put mine here on the bend of the inlet elbow..
that's about where I had planned on originally but sounds like there will meth spraying on it messing with the readings.
Steedman07
Classified's Moderator:)
Connecticut
Ya, I wouldnt put it there if I was running meth, but where it is now, it gets the most accurate readings,Why Vortech puts the IAT with the MAF is beyond me..Like BBR said, somewhere along the intake runner or something like that for the meth
06BBR
Miami, FL
bbr, what sensor and gauge did u use to measure your IATs?
I don't have the exact part# on the IAT sensor, you can get a threaded type like the lightning and some older model mustangs came with it. Just do a search for threaded IAT sensor. You'll find something its around 30.00. Putting it in the manifold is cake, just pick a runner and drill a 1/2 inch hole (i believe) and thread it in. I used some epoxy to make sure its sealed.
I am using a datalogger to measure my IATs through the OBDII.
Steedman07
Connecticut
The IAt extension is one from Steeda..They sell it elongated just for the purpose of mounting it where you want it..Best $ I ever spent..Tuners can tune way more aggressively when they are seeing accurate iat's, not to mention it is way more safer tuning actual temps, not friggin temps being read before the blower..
JA BoostedSTANG
Jax FL
yea it's not tough I am just to lazy to take the intake Mani off, but u gotta do what u gotta do. Lol
its in the MAF, but it should be relocated to after the power cooler on the vortech kit, just before the TB is where mine is, some as mentioned above have it in a intake runner
05stroker
Never enough power guy!
Bullard Tx.
Thanks guys . Dont want to highjack to much . LOL I do thank you though.
Androdz
Banned
If ur a tool you deserve fire!
I didnt want to drill through the metal on my after cooler because that was the only way i seen to do it after the s/c, i was told putting it before the s/c was fine? I can easily relocate it and plug the hole but i was under the impression where i pit it was the best place in my application.
Plug the hole and put it 12'' inches from the TB and the IAT right where steedaman has it.
Andrew
Androdz
Banned
It comes with the MAF stock.
Sorry for the highjack JA but I have to ask . Where is the fac AIT sensor on our cars?
The Intake Air Temperature Sensor is part of the MAF
IIRC, its integrated with the Mass air flow??
Yes
Pins 1&2 are the IAT wires
If I had a Vortech Kit I would spray meth Right after the aftercooler and put the IAT here
Freaknazty
KEYBOARD NINJA
SOUTH LOUISIANA
i have no tech behind this but id think it would be better to install that sensor on either the furthest or second to furthest from the tb that way it would read the hotest iat's that the engine gets , i know they say the runner flows identical but we have proved that wrong already lol
Androdz
Banned
temperature variances wont be that much to matter hell currently he is reading the temps before the intercooler lol Pick the runner that is the most convenient and easy to drill/send the wires and such.
Andrew
