JA BoostedSTANG
bbr, what sensor and gauge did u use to measure your IATs?
I put mine here on the bend of the inlet elbow..
that's about where I had planned on originally but sounds like there will meth spraying on it messing with the readings.
I would think anywhere in that pipe would have the same effect.thanks stoker but on the underside some what right?
Sorry for the highjack JA but I have to ask . Where is the fac AIT sensor on our cars?Which is also where you would want your IAT sensor also, after the blower just before the TB..
I don't have the exact part# on the IAT sensor, you can get a threaded type like the lightning and some older model mustangs came with it. Just do a search for threaded IAT sensor. You'll find something its around 30.00. Putting it in the manifold is cake, just pick a runner and drill a 1/2 inch hole (i believe) and thread it in. I used some epoxy to make sure its sealed.
I am using a datalogger to measure my IATs through the OBDII.
Thanks I will ck it out.Its integrated into the MAF.
I just checked BBR's website
http://www.blowbyracing.com/bbriatsere.html
They sell a relocation kit for 34.99 with a threaded type IAT sensor.
Thanks guys . Dont want to highjack to much . LOL I do thank you though.its in the MAF, but it should be relocated to after the power cooler on the vortech kit, just before the TB is where mine is, some as mentioned above have it in a intake runner
DO IT NOW OR GET LEFT BEHIND. LOL!Holy crap, man. You're not fooling around with getting that installed, are you.
Glad you can enjoy it.
I didnt want to drill through the metal on my after cooler because that was the only way i seen to do it after the s/c, i was told putting it before the s/c was fine? I can easily relocate it and plug the hole but i was under the impression where i pit it was the best place in my application.
Ya, I wouldnt put it there if I was running meth, but where it is now, it gets the most accurate readings,Why Vortech puts the IAT with the MAF is beyond me..Like BBR said, somewhere along the intake runner or something like that for the meth
IIRC, its integrated with the Mass air flow??
