Torque specs for main, head and cam bolts? 3v motor
YellowRoush
Houston,Tx
I've been looking around and can't seem to find it anywhere Motor is about to be built just waiting on this info if someone could help me out.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Nothing in the sticky threads for "Service Manual Guides" in the 4.6 tech section?
YellowRoush
Houston,Tx
I'll check
Edit: I don't see anything I checked the whole thread.
matt06
St. Louis
i usually just tighten stuff as tight as i can get it then very loudly go "click" and move on....
im assuming you mean the cam caps, if so google taco bill cams and it should pull up his step by step instructions which is what i used for the cams in my car and had all the specs.
