Spacers and studs
Jucostud
booooost'd
North of Dallas
Just ordered arp studs and maximum Motorsports billit 1/2 inch spacers. Any know if I can cut the studs so I don't have to use open ended lugs?
psfracer
billy badass
Valencia, CA
Why would you need 1/2 inch spacers? Your car is perfect as it sits right now.
Jucostud
booooost'd
North of Dallas
I've got 7/16 spacers on the front now on stock studs. Not exactly the safest idea. Maximum Motorsports is the only company I've found that makes an actual front spacer for our car.
Jucostud
booooost'd
North of Dallas
Thanks man, and weather man, that link is for rear spacers only. I only need a half inch spacer in the front.
weather man
Persistance Is A Bitch
MN
I'm running a 7/8" spacer on the front and 1" on the back from the company I posted. They are hubcentric and the studs are strong.
weather man
MN
It's says rear only for there 1/2 inch kit.
Hmmm, no trouble running 7/8" on front so far. Used the supplied studs and my stock lug nuts. I e-mailed him when I bought and he siad no problem. Maybe drop him a line if you are interested.
Mustang-mike
Shwetty member
Florida
That's an awesome deal for spacers on that site, I might consider one of their spacer kits now.
Scott_0
OxFORD, Pa
to answer your question, yes you can cut them with no issues. Ive used a Dremel to do so in the past
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Screw the die on first. After cutting, screw the die off and it makes nice clean threads on the end of the stud.
