06LimeGT
Okay I will try to explain the issue as much as possible. Recently my car has decided to not start out of the blue. What I mean by that is that it will start fine after sitting for a while. Like overnight, during work but when I go somewhere and turn it off and come back minutes later it won't start. Not everytime but sometimes it does that. It doesnt turn over or make a sound. It only has started doing it for about 2 weeks now. The battery isn't even a year old. The alternator was recently replaced not even 3 months ago. I have had the battery tested twice now and both times it is at full power. I just had autozone test the battery, alternator, and starter. All showing good. What could be the issue because I have been thinking its the battery not holding a charge but autozone refuses to swap the battery since it is showing good. The battery cables are connected good and there is no corrosion. I am at a loss and beginning to get pissed because i don't even want to drive anywhere because I never know when I will get stuck. When I get jumped off it starts right up and doesn't make an odd sound or struggle. Anyone have any clue as to what else I could check?
