Removing valve guides
05stroker
Never enough power guy!
Bullard Tx.
Anyone ever done it on a 3v head?
I need to remove mine for the port work I am doing. It looks like they press in and out. Are there any tricks that need to be done to make it a smoother removal?
ummduh
Napa, CA
Not that I've ever done it professionally, but in machine class we just used an air chisel with a mandrel to knock them out. Re installation was the same way.
05stroker
Bullard Tx.
I found something like that on line. To reinstall them, how did you know when to stop?
Would an arbor press work? I know it will push them out with the right drill rod size but is it possible to get the head into a normal press? You could use a c clamp with drill rod, just protect the other side of the head. Maybe a large c clamp with the head on a bench so the other end is pushing against the bench bottom? Drill rod stock is readily available from metal stores. One place would be www.onlinemetals.com
Edit: Here's a direct link: http://www.onlinemetals.com/merchant.cfm?id=267&step=2&top_cat=1354
RocketcarX
95% of my weight is fuel
Colorado
wouldn't you just machine the exposed part away when porting? Most ported heads I've ever seen or done they were blended into the port job.
05stroker
Bullard Tx.
I have a 20T press here. Just want to be clear about the guides before removing them. I have seen some have lips and only go one way. Ours seem to be the same size all the way through. How do you know when to stop when reinstalling them>
I need to remove a lot of material on one side of the intake port that is close to the guide and I will destroy the guide. I will tapper them a bit after they are reinstalled.
toorbeenee
turbine lunatic
dubai
From what i know its little hard, The reason i say that is because of the alignment with the valves them self, if you are off by 0.0001 you can bend the valve
I just went through the manual and can't find it. I'm sure you will note where they are before removal and duplicate the position during installation. Make sure the valves don't hang up or have seating issues and you should be fine. All of the valves are stored in a way you can return them to their individual original locations right?
05stroker
Bullard Tx.
Yes, all the valves, seals, springs , retainers, ect are all bagged individually and the bags are marked. I would add the guide to the appropriate bag as well so there would be no chance of mixing them up.
I am going to mark one and try to press it out this morning after I make a tool to press it with.
I also have the correct reamers that where used to setup my heads in the first place so I can check the guides upon reassembly to make sure the clearance is correct.
tmcolegr
It's All About the Build
Central, FL
FWIW - I would suggest using a valve seat concentricity (run out) gage after installation of the guides to be absolutely sure the guide is perfectly square to the seat and the bore in the valve guide is centered within .001". If it's not perfectly square and centered to the seat the valve won't seat properly. In theory it should be but it's nice to be 100% sure.
Reason why I always grind the valve seats after replacing the guides
05stroker
Bullard Tx.
Im thinking about having my machine shop reassemble the heads and grind the valve seats for me when they deck the heads. Then they can pull a vacuum on them, check clearances, and test them prior to installation.
tmcolegr
Central, FL
I noticed in your other thread you mentioned using a different head gasket. When the heads are surfaced, what RA micro-inch finish is required for those head gaskets? Is the RA micro-inch finish for those head gaskets different than the current surface finish on already on the block?
psfracer
billy badass
Valencia, CA
I know mine had to be machined a certain way in order to use the cometic gaskets (vs just standard Fel Pros) which worked great. 16:1 compression + 200/250 shot of N20 and the head gaskets looked great when I took the motor apart. I forget how "fine" of a finish it was, but it was very smooth.
tmcolegr
Central, FL
That's exactly my point. Each different type of head gasket requires a specific RA surface finish and that spec should be readily available from the gasket manufacturer. Hopefully the head gasket he's planning on using requires the same RA finish as is already on the block.
05stroker
Bullard Tx.
I will have to check with SCE and see what there gaskets require.
05stroker
Bullard Tx.
I made a tool today and setup my press to do the job. It was to easy fter that. One big pop and they slid right out with the press.
Nice. Do you have new guides to put back in? If so are they final size or is that saved for after they are installed to straighten out any distortion that is the result of installation?
What is the advantage of bronze over steel? Lubricity?
05stroker
Bullard Tx.
The same guides will be used. That is why everything is bagged and numbered. After install they will be checked again. They are not very old. If they where new I would ream them after installation.
As for the guides, yes. If sized correctly (don't remember the number off the top of my head) they work very well for my application.
