E85 question: someone school me
madrussian
T-101
Ramsey/MN/Midwest
I was curious of how much 2011 gt500 pumps with hat would go for around here? Im upgrading to e85 so stock fuel system would have to go. I just sold bap and 72lb injectors. Have fuel rails, hat with pumps, fuel lines. Just curious what it worth.
Sent from my SGH-M919 using Tapatalk
AndrewS197
Indiana
Bump. Forgot I have 47# gt500 injectors laying around. Still too small for corn??
They will support up to at least 500 if you have enough pump. IIRC I was able to make 53x with the long gt500 injectors and gt500 pumps. I know that I had to get out of the throttle because it was going lean.
AndrewS197
Indiana
Ok,cool. 47 pounders with gt500 pumps it is then. Should I get a wire upgrade too? Bap? Or is that overkill for 450rwhp?
Definitely get the wire upgrade. Then see where your fuel pump duty cycles are.
Edit: The GT500 pumps come with a wiring harness that includes a heavier gauge power wire. That will work fine.
Do them both. I noticed a drop in dc going from the gt500 12 gauge wire to an 8 gauge wire. A single 40 amp bap will power both pumps fine. You don't need it now but will in the future.
AndrewS197
Indiana
Ok , will do. Since I'll be doing the supercharger install and converting to e85 at the same time, will I need a tune for the initial start up? I know I wouldn't for just the SC, but I'm not sure with the e85.
yes you better get a new start up tune
Quality tuner can get u a start up tune to work from.
AndrewS197
Indiana
There's a Ford dealer close to me that is also a speed shop. Sutton Ford in Matteson, Illinois. Dunno if anyone has any experience with them. A guy I know has a Procharged Mach1 that was tuned there and far as I know, it runs fine. But I heard they lost their top tuner, so I'm skeptical.
Also, I was checking on eBay for a Walbro 465....don't see any for $120-$150. More like $200 plus....lol
BadHabit2Break
Houston, TX
So I have been thinking of switching to the corn lately.
I keep reading about 47lb injectors and see there are 2 different ones.
47# Fuel Inj 8 Pack M-9593-G302
47# Injector 8 Pack M-9593-LU47
Which is the correct one for my setup. N/A here.
striker 5
Alright I have a question now - my set up is stock bottom end a whipple , 63 lb injs , and gt500 pump what do I need to do to run e85 just get a tune . E85 wont hurt any of the lines or anything like this .
Weou09
Bham, Alabama
On a stock bottom end you would need nothing else. I dont think the benefit would be worth the draw backs.
LU47.
It won't hurt the lines provided they are stock. A base tune is as easy as changing the stoich in your current tune. If your current tune is driveable then the base tune should be driveable and get you to the tuner just fine.
