No it's not a daily
I don't want to buy something twice
I plan on trying to be competitive in scca autox.
But you're operating under a budget, right?
If it's going to be competitive, then you're going to need control over spring rates and damping characteristics, so that pretty much means coilovers.
Since it's autocross you're talking about, I'd expect the difference between monotube and twin-tube dampers isn't going to be nearly as important as it would be in something like endurance racing.
I suspect the only way you're going to get solid advice on the dampers is by talking to someone who has run both GC coilovers and monotube coilovers in autocrosses and who isn't actually selling anything. As far as I know, Whiskey11 is running GC coilovers for autocrossing, but I don't know if he's ever run monotube dampers.
That $1800 difference between the GC coilover setup and the MCS coilover setup will buy you a lot of additional tuning capability (e.g., adjustable sway bars, adjustable panhard bar, etc.).
You
really should talk to Whiskey11, because he's also running competitive autocross. There are class rules that will restrict the modifications you can make, and force other choices upon you (e.g., Whiskey11 got a torque arm because, if I remember right, lower control arm relocation brackets would put him in a different, and much more difficult, class).
