Tons of 3V parts FS... AM and OEM
NjsGT
Back in the game....
NJ
What would be needed for 2010 gt?
You would need whats it listed above if your car was a 07-09 car. The only diiference is the part number for the 2010 power steering kit is different.
4FU010-101 Bracket P/S 2010 GT
Honestly if you're handy you really just need 3' of 3/8 power steering hose some straight brass barb fittings and some clamps. Then you just need to make a L shaped bracket. :beer:
bump! help me buy a 2.3 TVS fellas!!!!!
NjsGT
NJ
Vortech still available Nj?
Sent from my XT1080 using Tapatalk
Yes it is, still have it
Interested in the RST. Are you willing to separate it from the flywheel? I need a 6 bolt.
I actually have a spec 6 bolt steel flywheel if you're interested also, it's the one with the replaceable friction surface
NjsGT
NJ
Kurt, I have a modded coolant crossover that will work with your frpp manifold aswell....
NjsGT
NJ
Sweet. So you have all the parts for the non cooled setup?
All you would need is a power steering relocate kit and a PCV/maf kit from vortech. You can actually fab those 2 kits yourself. Some small cheap things like washers, hose clamps, and vac tubing are needed also.
