Yep, this is a good list right here. We've managed to only have one weekend out of nearly 100 where we broke the car badly enough to stop racing - when 3rd gear let go. Still was able to use the other 5 forward gears, and drove it across town to the dealership for warranty repair.Most common replacement parts we see at the track:
Pads, rotors, brake fluid, rear axle lube
Most common mechanical wear we see at the track:
Front hubs, front wheel studs, rear axle seals, Track-Loc differentials, various bushings (usually accident related, not worn out).
After a LOT more track use, these wear out:
Engine mounts, transmission mount, caliper bodies and seals, rubber bushing in the top of the axle.
There are other issues related to use, like if you run the tank too low, the pump burns up sooner than it should. If you jump the curbs, expect to replace upper strut mounts and tie rods. Shift with no mercy, expect to replace some transmission internals sooner than normal. Shift way up the rev range, higher engine temps and valve train wear start showing up. All of these things are manageable by how you treat the equipment.
And once you've upgraded beyond the worst offenders (clutch style diffs, under-achiever brake pad brands, overheating the front hubs by improper front brake cooling), and keep an eye out for the long term stuff, it just boils down to normal wear with the pads, rotors, tires and fluids.
Cheers![]()
Bmr ...control arms suck period as do Bmr parts !
The stock TracLock can last anywhere from a single track day to a year or two, depending on how you drive it, the type of tires you're using, etc. Upgrading to the Cobra/GT500 carbon clutch discs increases the longevity only slightly. The TracLock is also inconsistent, since it's effective bias ratio decreases as the clutches wear.
Really, you got less life out of the carbon clutches? I wonder if there were other factors involved. That's interesting.
I've never driven on a T2-R, but the Eaton TrueTrac has ~90% of the -R's bias ratio at half the price and is more robust...
Terry, I know you have professed that you have used a ton of break pads and have stuck with what works. I'm assuming that you haven't tried ALL brands and that you might have found Carbotech and was so satisfied that you didn't see the need to go elsewhere. But to the question...have you tried Performance Friction track grade pads?
I knew the stock diff was a turd, but I didn't realize how quickly you guys were rebuilding them. I've put ~25 track hours on mine since it was last rebuilt, and right now its performance is garbage. I was hoping to last through one more event before dumping money into it, but it sounds like it's already beyond toasted. I'm hoping that only the clutch discs and fluid need to be replaced...
Yeah, that would drive me nuts. I'm fine with an annual rebuild (6-7 HPDE/TT events for me), and even a semi-annual rebuild is tolerable if it's just fluid and clutch plates. Anything more than that will get old pretty fast. I'll have to see the carnage lurking inside my diff to see if I want to risk it in the future. I'm just hoping that the carnage remains inside and doesn't spread elsewhere...There are several nationally-competitive SCCA guys who rebuild their TracLocks after every event.
I guess they just prefer the way the TracLock performs. That sounds like too much work to me.
We switched to the carbon clutch pack in our diff and had to rebuild it every three events. Between the heat generated and the failing, inconsistent diff, we quickly decided to go to a Torsen and bought the T2R. Diff heat is much improved and the seals, bearings and fluid is lasting much longer with the Torsen.
Clutch failure is almost inevitable with stock Valeo setup. I had 23k miles with 6000 on track when mine let go on a 3-4 upshift at Summit Point. Marcel spring shot right out of the disc and jammed the pressure plate. Have McLeod RST and have had no issues over the last 5000/2500 miles. Friend of mine has blown 2 Ford clutches in successive years at Watkins Glen, also damaged two transmissions in the process, he stepped up to a McLeod setup as well.
Steve
That sounds like one of two things:There are several nationally-competitive SCCA guys who rebuild their TracLocks after every event.
