Stock Half Shafts vs DSS 1400hp Halfshafts
REDS197
Denver
Picked These up from lethal on Black Friday for 15% off. They are almost 30 lbs heavier! Install is not bad it took about 2 1/2 hours.
claudermilk
SoCal
I though someone else has, too. I swear I'[ve read about at least a couple of shops breaking them, but Bama for sure. I think they posted their video of the failure around here (American Muscle).
Why do those beefed-up ones look longer?
REDS197
Denver
There is a left and right side. They were just mixed in the photo.
fdjizm
Drag Queen
30lbs heavier each than stock? holy schit.
Drag racers nightmare, 60lbs of added rotating mass. :roflmao:
REDS197
Denver
24lbs total. Not each.
Stock weighed about 21lbs each. These weighed about 33lbs each.
This is on a home scale so exact weight could be wrong.
TGR96
el blanco nino
Huntsville, AL
So, are you planning big HP numbers in the near future? I would think these would be overkill for a stock or even a bolt-on car.
REDS197
Denver
Yes I am.
I had an engineer at Sema tell me stock half shafts will NOT hold up to drag racing even with mild bolt ons. If you drag race they are a must.
TGR96
el blanco nino
Huntsville, AL
Ah yes, I've seen that video. I forgot it was just a cai and tune car. I bet these half shafts will be a hot seller for the s550 crowd.
The CAI isn't doing anything..esp on a 2015 which has a superb air box...and huge snorkel between it and the grille. So just a tune + sticky tires will do the job.
Dubstep Shep
WUB WUB VROOM VROOM
Houston, TX
Shit, it might just do it on sticky tires.
Was AM using slicks or what?
lostsoul
2014 vett or 2015 stang..
Gay Area
damn.. it broke that easy.. ford had to know. at that level maybe even stock and some hard racing would eventually break.. not good.
