fuel pump question..
BLT2BTU
still have the stock fuel pump what do you guys recommend just have a few bolt ons maybe a little zex kit so maybe just a step up
Wes06
tekk
Asking questions about which part over another isn't tech. Read the rules
weather man
Persistance Is A Bitch
MN
A member since 2009 should know better, even if you are just a ghost.
BLT2BTU
thanks bullet. and yes I am a ghost I suppose... bought the car new, sold it in 2010 ish and recently got it back
s8v4o
A different pump is easier and cheaper.
AEM 50-1000 (for gas)
AEM 50-1200 (E85)
Weou09
Bham, Alabama
AEM 50-1200 (E85)
Agreed. I hate how everyone jumps straight to BAP to band-aid a weak fuel system. It is more work and more risk, sometimes even more expensive.
s8v4o
That's why I'm doing a GT500 system with dual AEM 50-1200 for my HP performance turbo kit on E85 :thumb2:
Got the setup for a good deal (thanks Jason) and it had dual 405's in it. Sold the 405's to offset the cost of the AEM's.
It's too bad you'll be running your new setup initially with the different gears. I would love to see a datalog of boost pressure versus RPM with your 4.10's and then with the 3.31's. Oh well.
JeremyH
3V Fuel Guru
Virginia Beach
I would do a wire upgrade, but you don't need a pump upgrade for a bolt on wet shot (100-150) non boosted car.
Weou09
Bham, Alabama
that aem works in an 06?
Yes. Pretty much any pump under the 405s is direct swap.
i'm the same way but about baps but i dont know to much about drop in fuel pump replacements.
It's fairly easy. The hardest part is getting the lines of the stock fuel pump. It can be a bitch.
You sure? That would be pushing the stock pump pretty far in the rwhp range.
Weou09
Bham, Alabama
If the built rear end is still available in for sale section, i could possibly do comparison.
Doug M
Fast Cars & Freedom
AL. Baby
Larry, did you get the pump you picked up from the forum yet?
JeremyH
3V Fuel Guru
Virginia Beach
Yup. Don't need bigger injector eithers. A lot of wet shot guys running just the wire upgrade making 400-450rwhp oem pump. Any more than that and you will need more pump or a bap.
Yep. Already repinned it with a 10 gauge wire and deleted the pprv. Going to run a -8 hose from hat to rail and see how far stock gt500 pumps will go on e85.
We saw just over 700rwhp same setup on e85, only with a bap as well.
Just the PPRV delete and 8an line and filter upgrade is good for 25% drop in duty cycle.
Weou09
Bham, Alabama
Cool. I'll probably run out of injector first then. No BAP for me. If all else fails 100lb injectors and bigger fuel pumps. I won't be running stock rails either. Push the returnless as far as I can lmao
