Best Limited-Slip Differential
V-6Power
I'm looking at putting in a Limited slip differential in my rear end but don't want to pay over $400 for one if I don't have to.
Does anyone know of a cheaper differential?
My 2005 V-6 takes a 7.5in, 28 spline.
If also know of a full spool, that would be fantastic too.
Thanks in advance. :helpme:
Wes06
What part to buy isn't tech
Will be moved
But most recommend upgrading to 8.8 rather than building 7.5
Meh it's a V6..... So it'll stay.
Better to spend a bit more and get a take off 8.8 IMO
$400 will get you a used 8.8 axle.
I have no idea if Eaton makes a Truetrac for the 7.5".
Gabe
Whippled Coyote
Yeah, just swap in a 8.8 especially if you're gonna build it up at all ...
JimC
It's hard to even find a new differential for the 7.5. And if you do find one, it is usually cheaper to just pull the 7.5 and put the 8.8 from a 2005-10 V8 or any 2011+ in its place.
cbass
m̶o̶u̶t̶h̶s̶e̶x̶
Rochester, NY
You could weld the diff and make it a spool yourself.
V-6Power
Sorry about the wrong location for the post, I figured this was a tech question.
But thank you for all of the suggestions. If I were to try to do a rear axle swap, where would be the best place to find said axle?
Also, what is my stock gearing? I'd like to keep the gearing where it's at.
Call around to your local junk yards and get an idea what they are asking for them and what kind of mileage is on them. Regardless of mileage, if you buy a used one then you want to pull the back cover to inspect the gears and change the fluid.
V-6Power
Where would the best place be to find a new axle?
I just have a thing with buying new if I can afford to do so.
Scr3mnYel05
Screaming 6
Tomball, TX
Once I get the money together I'm swapping out my rear and will be selling it... has moser axles and 4.10 motive gears with ford racing LSD... but I want to tear it down first to see if when I traded it in last time that they didnt change that out...But I'll be starting that project probably after new years because I will be in mississippi
JimC
Try car-part.com and put your location in for the search. You can also try newtakeoff.com.
The stock gear on the 2005-10 was 3.31. A 3.55 was optional but I don't think that it was available on the 4.0
Speedboosted
Found missing cylinders
PNW
I went through this question over the summer. I started checking craigslist and forums regularly for a nice condition 8.8 and eventually ran across one with 30k miles that I ended up paying $120 for. It needed a new pinion seal which is not a big deal at all since the pinion flange needs to be changed.
My point is that there are really good deals out there for them if you just be patient.
JUSTA3V
Moar Throttle!
Queen Creek AZ
I bought my rear end complete with 4:10s from new take off . Com. I don't know if they are still around or not.
Speedboosted
PNW
It is, but rarely do they ever have anything I'm interested in. I do check it periodically though
07TR
Pa
Be patient and look for a rear on eBay that's what I'm doing
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Although, what you're asking about is a Ford trac-loc for a 7.5. But, I agree, by the time you buy one and pay someone to put it in, you can get a 8.8 takeoff.
07TR
Pa
Best advice and mike is my go to source so trust him
