2015 5.0 crate motor
Black GT
Does anyone know if my 2006 Mustang GT ECM will work 2015 5.0 crate motor. I want to replace my 4.6
05gtowner
So. Cal
To much work for not enough return. I would just build the 3V and add FI. Or buy a 2015
Black GT
UltraKla$$ic[IMG said:
http://i170.photobucket.com/albums/u257/UltraKlassic/1367173004_zps3e32d132.jpg[/IMG]you don't know me................don't get on forums that often for this reason Always some jackass making smartass comments. Go buy you a Camaro and join the rest of the.............
QuickShift281
Northern Ohio
Will not work. If you do follow through with a 2015 Coyote engine, you DO need a 2015 specific control pack. The cam controls as well as a few other parameters are different for the 2011-2014 GT engines to the 2015-2016 engines.
weather man
Persistance Is A Bitch
MN
UltraKla$$ic[B said:
you don't know me................don't get on forums that often for this reason Always some jackass making smartass comments [/B]
You need to stick with a 3V long block or short blocks that use 3V heads. You could swap a coyote 4V, but would really need a donor vehicle to make it work. There are other combo's, but looking at a lot of work.
Black GT
Thanks
Black GT
Thanks, Looked into 4v better off and find a used GT500. I've had this car since new looking to see what route to take money wise. if I keep the 4.6 I would go with a stronger block for sure with forged internals. I have a old Boss 429 motor don't know if I should take that route my car just a toy to me.
nelsonbullitt
Houghton, Michigan
I looked long and hard at this a few years ago with my 2009 Bullitt. Upgrading to the coyote engine will require not only new ecm but you would run into problems with gauges and other electronics. I decided to sell and buy the 2011 GT. Out of the box the engine is all aluminum with better designed 4v heads than the older (2007-2012) GT500s. Plus you can safely get 600 rwhp out of the stock engine.
Other than that, sc your 4.6 with a vortech. I safely got 488 rwhp out of my '09 Bullitt with great driveability and stock internals. You can also go with a MMR type engine like:
http://www.ebay.com/itm/4-6-Forged-...m27bc1d7785:m:mw83Pa9rs79s-eImZ20GqoA&vxp=mtr
06silverbullet
orange county, ca
butt hurt much,
a little searching and some common sense goes a long way, if you don't at least try to search a little you're gonna get called out.
a simple search of 5.0 swap/coyote swap will yield any answers to just about any question you could have on the swap.
http://lmgtfy.com/?q=coyote+swap+s197
G.T
Earth
i'd lock out the cams.. get some pigtails to adapt the wiring harness connectors and have some fun
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Sounds like YOU need a Camaro and a Snickers. LOL.:gayflag:
Darren, I just thought of something. If you took the depreciation on your mustang(S)..then divided by the mileage...... each mile 'driven' would cost a megabuck !
07TR
Pa
Lmao
ford20
White Plains,NY
:thud: ...... Can we go a thread without someone having to comment about Darren not driving his car
TGR96
el blanco nino
Huntsville, AL
It's just too easy, though. Like blaming Obama for everything wrong in the world.
