I've been looking at these cams for quite some time. They are Lunati 21270716.
Lift is just a little over .500. LSA 112 and ICL 102. This means I'll get to use vct again. Durations are right between comp 127500 and 600.
In short this is the cam I'd use if I was calling out a custom grind with one exception, I'd keep the lift to .500 max.
Anyway, I was just looking around the internet and found that Summit had them for $668 today. It was a hard choice between these and the slightly more aggressive 21270718.
I couldn't pass up the price, these cams should be just about perfect for my setup. They also sound slightly nasty.
Back to Home : Cams : Ford 4.6L & 5.4L Modular 3 Valve (2004 - Present)
Voodoo Hydraulic Roller Swinging Follower - Ford 4.6L & 5.4L Modular 3 Valve 271/279
Product Description
Hydraulic Roller Swinging Follower Cam Set. Awesome street cams with rough idle. Good mid range and top end. Like 4.10 gear and 3000 stall. Need springs, phaser mods and custom tuning.
Previous Part Number: 58016
Jobber Price: $743.91
Product Description
- Advertised Duration (Int/Exh): 271/279
- Duration @ .050 (Int/Exh): 233/241
- Gross Valve Lift (Int/Exh): .500/.508
- LSA/ICL: 112/102
- Valve Lash (Int/Exh): Hyd/Hyd
- RPM Range:950-7000
- Includes: Cams Only
