Error P013C
lsflp
Hello everyone, I have my Mustang GT 2013, completely stock with only 24538 miles, yesterday I received an error P013C, so, what experience do you have ?, What should I review? whats its the part number of sensor?
Thanks so much
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
It's the secondary (downstream, after the catalytic converter) O2 sensor on bank 2. Check the wiring connections. If they're OK, replace the sensor.
lsflp
Vince, the part # its : Motorcraft DY1185? or DY-1162?
redfirepearlgt
Any chance you had recent work done such as a clutch upgrade that would require the mid-pipe to be removed? If so also inspect for proper sealing. I had that happen after a clutch upgrade. Car would generate that code as I recall but only on a long drive because of the leak. Found the leak, reseated the connections at the header to converter conx and where the converter to Hi-pipe conx. No problem thereafter.
lsflp
I never touched any screw in my car, completely stock, I will search one ramp and check everything.
Thanks
lsflp
the problem was fixed, one clamp was broken in the driver side.
redfirepearlgt
That will do it. Mine was a leak caused by the midpipe to cat pipe not being properly aligned and tightened after a clutch upgrade. Glad you got it resolved.
