Aussie-Parnelli
Hi
I have a heavily modified Saleen S197 which I took to the dyno several weeks ago. The car was running fine when I dropped it off.
Got a call to say there was an issue and was in limp mode
Unfortunately here in Australia there are not many S197's
Took the car home and it will only start with the throttle body disconnected and run in the limp mode
Tried reinstalling previous tune but to no avail.
With the throttle body connected it is making a chattering sound and won't turn over
It is showing these codes P2107 and P2110
Cannot clear these codes with my SCT tuner. Have 3.87 volts at each pin
Have put a new throttle body on.....same issue
Have changed numerous parts off one of my other S197's still same problem
Checked all fuses and relays plus earths....still nothing
The dash is showing "check charging system" and "DTE Data Error"
Running out of options any ideas or help would be appreciated
