A little update today since no one seems to know anything about this. I did change the "As Build" on the cluster 720 section 720-01-01 to F798-EF61-08 and the 720-01-02 to F80F-0000-31. This changed the automatic V6 to a Manual V8 with success. Still no Track Apps line item and the Automatic Oil Temp line is now gone. When I changed the line item 760-01-01 to 056E for Brembo Brakes, I got lots of errors with the ABS. It says my Brembo module has failed. I guess if you up-grade the brakes to a Big Brake Kit, you must replace the ABS modules to Brembo.
I still have not done the keys yet. I do not want to brick the car. It might be in order to get the Track Apps to work in the cluster, you must have the Track Package in the car. Standard brake code for both V6 and V8 is 016A. It's EZ to go back and forth as Forscan allows programming by line item.
