Throttle body calibration
ddorsten
Anchorage
I got got a ford performance 90mm throttle body for my 2014 mustang gt. It says it needs calibrated and I’m wondering how I can do that. I installed it along with a new boss 302 intake manifold and boss 302 radiator. Tuned it and tried to start it and it turns once and dies. Help please.
Iceman62
Bullitt 6005
NE
Didn't come w/ any instructions, guessing you didn't check the site you purchased from to see if there's anything there either? Where'd you get the parts?
FMBoss
I believe by “re-calibrate” they mean to tune.
Under "tech specs" tune required = YES.
86GT351
Sunny South Florida
For the Intake and Throttle Body a TUNE is required. Due to the EPA mess maybe they changed there lingo?
86GT351
Sunny South Florida
  • Fits 2011-2014 Mustang GT with manual transmission
  • Original equipment on 2012-2013 Mustang BOSS 302, Ford Performance BOSS 302S and BOSS 302R Race Cars
  • Made from light-weight composite material
  • Short runners for optimum flow at high rpm
  • Includes unique "Ford Racing" intake badging
  • O-ring intake gaskets included
  • BOSS 302 Intake Manifold Install Kit, Part No. M-9444-M50B, is recommended and includes the necessary production components to complete the installation. (Minor wiring harness modifications required)
  • Calibration is necessary to prevent engine damage!
  • Calibration NOT included!
  • NOTE: BOSS inlet tube does not have provisions for aspirator tube hook up common to automatic transmission equipped 2011-2014 Mustang GT
ddorsten
Anchorage
Yes I figured out that calibration means tuning and I had a tune for it and it’s doing this. I did repin the new connector. It came with blunt instructions that I followed. Double checked after it wouldn’t turn on.
Have you checked for trouble codes on the ECU? Can you verify that the TB is responding to the gas pedal?
ddorsten
Anchorage
I did get a P1602 when I first plugged up the tuner but it doesn’t come up anymore.
