I have searched this so either I'm not using the correct key words or it hasn't come up.
I recently fried my stock alternator and decided to go with the PA 200a one. My question is, while I know I have to swap the pulleys, if for no other reason then the PA comes with a 6 rib pulley and I have an 8 rib pulley setup, I was also told by Jim III that the alternator has to spin in one direction. Now looking at the alternator it spins freely in either direction. Why does the alternator have to spin in only one direction to work properly? I know you can spin a generator in either direction and it will work fine. I know an alternator is different from a generator but why would you need to spin it in only 1 direction. I also don't understand how swapping the pulley is going to change the direction of spin when I put the alternator in my Saleen setup car. I am pretty sure that the Alternator is turned around and the direction of spin is going to be changed from stock too. This is something I mostly want to know for my own knowledge, obviously I'm putting the 8 rib pulley on, I just what to know how this is working.
