ok i will look into one of those, ive asked this like 4 times . would there be any problem with me making a custom air to air intercooler setup? it seems like it would be pretty simple to do ?
You can make anything you want custom, just look at some of the crazy set-ups on this site alone. If it were me, I would buy a set-up done and that has everything you need for the install. Keep in mind I am far from a mechanic, so that is what "I" would do..If/when I get an aftercooler(I wont get/need one till its time to run some real boost with a real bottom end), I will go with the after-cooler thats air-to-water cooled kit that Vortech offers.
Unless you are drag racing ... is an I/C really necessary?? I would think with just an occasional Stop Light race or on-ramp run a non-I/C setup should be fine. I'm considering Brenspeeds Paxton Throw-Back ... non-I/C and around 440 RWHP ...
An I/C or meth is not "necessary" per say. It just makes sense to not run an in-efficient blower remotely agressively. You "can" tune it to make power, but you will be buying a replacement engine very soon. The goal is to keep the IAT's down as much as possible. And the 440 hp advertisement will really end up making about 360 or so whp on a hot day and brutally high IAT temps..
