Dreadknought
HOON MONSTER
Oh no is really easy. Its just a little metal clip that needs to be pulled out of the plastic coupler at either end. it can be done with a small screwdriver or pick. It will be pretty easy with the engine out.
If you put a JPC steel braided line (good upgrade BTW) on the only thing to worry about is where the line connects to the master cylinder on the firewall, be careful when popping the clip that you don't lose it. Try to pry it out with a long screwdriver in one hand and a telescoping magnet in the other hand to keep in contact with the clip.
I'm thinking you are the same Anthony from another forum who took his tranny out about 10+ times adjusting adjustable slaves. You must have it down to a science.
It wasn't 10 times, but between my car, my son's car and some side jobs I've had some of these trannys out. We had a few of those adjustable slaves, 2 McLeods and 1 Ram. I like the McLeod better. I don't have it anymore because of the RST which doesn't over power the stock slave like heavier pressure plates do. The best thing I ever did was the dead blow hammer in the front of the tunnel. You just wack the fucker all around the area where the bell housing goes and shoot some spray paint on all the scratches the bell housing caused by removing the transmission. popping the cherry on the first tranny job that hammer does more than just help with bell housing removal, also helps release a little fustration, lol
Shifter87,
This is man's work...give the bitches their equal rights and stick them under one of these cars, yeah right!
Yeah that little clip wont secure on the plastic elbow, is there a trick Kind of BS two bolts and a slip hold this slave on and a piece of metal that weighs less than an ounce is giving me a hard time.
At first I thought the new slave didn;t measure exactly the same as stock but they do. I unbolted the new slave and put the plastic elbow on and the retaining clip and it held. Put it back in the trans and put the clip in and it pops right off Whyyyyy.
Under than that stock clutch and pressure plate are out and I will be reusing the stock bolts with loc-tite, I just need to un-fuck this slave issue and take out the stock flywheel.
Going on a run now hopefully I will have some life saving input when I get back.
That clip has been th discussion of many cltuch threads the past 5 plus yrs. Don't let that littel basterd get the best of you. You will notice the line once attached has a little movement. You just have to find th correct postion seat where the clip pops/snaps on. In regard to p/p bolts, loctite is a known work around for this and many other shop jobs vice buying new bolts. Some torque to yield bolts it's best to replce after torque'd twice.
BTW...Every man needs a challenge every once in a while and what doesn't kill you only makes you stronger...or something like that I was once told by my Navy Master Chief, and a couple of Gunny Sarge's when I was gettin my ass kicked.
Lol oww the pressure.... Are you refering to the slave connection inside the bellousing or the hydralic line connection on the outside? If its the connection on the inside mine seemed like it was loose whenever I put it in but it has stayed so far. The metal clip on the outside should actually go through the coupler.
Looks like alot of smoke on them parts.Well glad to know I am not the only one, and yeah I will make sure if I do this again to buy everything well ahead of time.
The outside, the retaining pin that holds the elbow to the slave adaptor. In the ford instructions it says get a new one just like the bolts but one big fucking problem no one carries it so I am reusing this one I could probably find a retaining pin this size at Lowes but not going that far yet I am going to keep trying.
Yeah I tested the pin after I read that to make sure it help with the slave in my hand and it help find couldn't pull the elbow off but with the slave in (not bolted but in) I tried again and it was easy to pull off which is the current problem.
Hear are some pics of the stock cluth/pressure plate and the stock and new slave the stock one was done. I also had my wife snap a shot of me under the car siting up in the trans tunnel taking out the last clutch bolt, I though it was kind of funny how much room I have with the car skyjacked if you will.
One more question (at least for now), what tabs are people cutting off the tranny I am going to hammer the hell out of the tunnel but would like to do this as well for future work.
Looks like a lot of smoke on them parts.
