TPMS Tube 07+
irishpwr46
Official Site Vandal
NYC
So you got a set of wheels with no TPMS. You, like most others, hate that light in your peripheral vision. Build one of these, and get a set of sensors to put inside and forget that light forever. It works best with your stock sensors as you wont have to reprogram the system, but if you have the tool, you can do it easily enough.
parts list
1- piece of 2" pvc pipe 10-12" long
1- 2" pvc end cap
1- 2" pvc by 2" female adapter
1- 2" pvc threaded plug
1- bolt style Schraeder valve
1- can pvc primer
1- can pvc cement
4- TPMS sensors
*NOTE: 07-09 TPMS sensors will not work with 10-11 cars and vice versa*
Also, if you have the 10-11 sensors, you may have to change all that two inch to three inch. I dont have any on hand to check if they fit into the two inch pipe.
Start by drilling an appropriate sized hole in the 2" threaded plug for the air valve. This one worked out to be 1/2". Then install the valve in the plug.
Next, prime and cement the end cap and female adapter onto the pipe. Have a beer and note how much it looks like something you saw some girl using in a porno one time.
Next, if you have the stock sensors that are still programmed for your car, you can put them into the tube. Use some sort of padding to keep them in place and prevent them from rattling around (personally, im using a couple of newspaper sheets). If you dont have the sensors, you will need the TPMS reset tool. (about $40 from american muscle). I would suggest laying one by each wheel as it will make it easier to reset them and less possible to mess it up. I copied this next bit from another website.
To get the Sensors in the learning mode. Just follow this on/off key sequence.
1. Start with the key in off position and press and release brake pedal.
2. Turn the key to on position (not start) and after the first chime turn it to the off position.
3. Turn the key to on position (not start) and after the first chime turn it to the off position.
4. Turn the key to on position (not start) and press and release brake pedal and turn key to off position..
5. Turn the key to on position (not start) and after the first chime turn to off position.
6. Turn the key to on position (not start) and after the first chime turn to off position.
7. Turn the key to on position (not start) and leave in on position. Horn will chirp once and the message center will display the following message:
Take your sensor and hold it opposite the valve stem and point the sensor to the inside of the rim and press the button. In approx. 5 seconds the sensor resets, the horn will chirp and your the message center will notify you to train the next sensor.
Do the same to the RR and the LR wheels. After the LR is done the message center will display the following:
If the Training is not successful, the horn will chirp twice and you must repeat the training process.
That's it! Takes less than 2 minutes to do the entire process.
Now that we all have sensors trained to our cars and installed in the tube with sufficient padding, its time to plug it and pump it up. Put some thread lubricant (teflon is fine) onto the male threads and screw the plug into the female adapter. After its good and tight, you can use a bicycle pump or equivalent to pump your tube up to 32 psi. You can also paint the tube or whatever you want to customize it. Toss it in the spare tire well or anywhere else, and forget that light ever existed.
overall cost is about $20 for material.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Where is the TPMS during this step?
irishpwr46
NYC
you can disregard that. if you have the sensors out of the wheels, just lay them on the ground next to each wheel and point the tool at the sensor. i had to get pretty close, but it worked either way.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Now I see. thanks!:thumb:
Kuplex
Software Developer
Knoxville, TN
I may do this when I put on new tires so I can upgrade my rims in the future without worrying about new bands / getting a tire& rim package. Nice write up.
one eyed willy
Pizzle fo shizzle
Lakeland FL
great write up,thanx!
just did this tonight, but i got a few questions.
i bought the remote, i "think" i got them all learned in, first one was a single honk, when i went to do the second one it honked twice, i think i had them too close together ( i had all 4 on the trunk deck when i was doing them) when i was learning them in and it caught 2 sensors at the same time, fourth one learned in....i checked the info center and it said "tire training completed"........so im thinking the new sensors are learned in?
put them in the tube, i no longer see the "fault" message, but i am getting " low tire presure" message.......
i read where another guy had to turn the car on/off afew times before the message cleared......do i need to drive the car at all to get the message to clear? i tried wit with 35,40,45 psi in the tube.....
irishpwr46
NYC
what i do is actually lay the sensor down next to the wheel for all four of them. i "learn" them that way to be sure i get it. second, make sure to test your tube for leaks. pump it up and hold it under water. as for the low pressure light, try and drive it a while and see what happens. i also keep my tube under the passenger seat to make sure all the sensors are in range of the system.
one eyed willy
Pizzle fo shizzle
Lakeland FL
update on my situation:
i relearned in the sensors by placing them by each tire, this time....soon as i turned the key the "fault" and "low pressure" lights were gone! no driving around or turning the car on/off a few times.
thanx again for the write up!
one eyed willy
Pizzle fo shizzle
Lakeland FL
Ever since doing this ..... It works fine for 20-30 minutes of driving, but on long trips the light pops back on.....like it knows the tires are not rotating......anyone else have this issue on long trips?
dark steed
Resident noob
Winder, GA
My TPMS light goes out after about 30 miles of driving. The sensors are in the garage and they reconnect every time I pull into the driveway, so you don't have to be too close to them!
jpe
Wisconsin
mine flashes a couple times i think and beeps but goes right back off. i don't have the sensors in my car at all.
sticksandstones43040
From what I understand about Mustang TPMS, the sensors have accelerometers that wake up the sensor when the car moves. The sensors go back to sleep when the car stops moving to save sensor battery. If the sensors inside the tube never move, they never wake up and the TPMS control unit produces a DTC when it sees that the car is moving, but there is no signal from the sensors. I don't know why the DTC isn't permanent, though.
I don't know what differences there are between the model years. But I just changed wheels on my '07 with new TPMS sensors. I tried to teach the vehicle the new sensors, but apparently there was a problem with my sensors. So I would put the car into teach mode and then it would time out (two horn beeps) because I couldn't get my sensors to wake up. So I drove the car around like that for a week waiting on new sensors. Anyway, in this condition, the TPMS warning light would flash for about 20 or 30 seconds and then never again during the drive cycle. I found this to be very easy to ignore. In fact, I forgot that it was flashing at all after a couple of days. If you want to drive without sensors, you may consider trying this and see if you can ignore the flashing (or at least it doesn't bother you).
EGNARO
Orange Backwards
Long island
I just had a set of new sensors put in my rims , had to buy the AM tire band kits however. But this is what I would have done if I wasn't already getting the tires dismounted
one eyed willy
Pizzle fo shizzle
Lakeland FL
If you have he my color dash then it never goes away unless you hit the reset button.
So, to be clear, are you saying the warning light never goes away using the OP method (i.e. teach the sensors and then install into pressurized tube)? Or are you saying that, after putting the vehicle into teach mode and then turning the key off without teaching any sensors, you get a solid warning light that doesn't go away.
I'm mostly just curious. I don't have the color dash and I don't have a reset button - at least as far as I know.
