05 gt p0191 error code
06monera96
LeShawno
Ontario, Canada
Hey everyone,
Engine threw code p0191
Car run fine, i notice when turn the ignition without starting the engine, I can hear the fuel pump continuously pumping , with a high pitch once started
Usually it would prime and turn off until you start the car.
Could it be my fuel pressure sensor went out?
Car run's perfectly fine, but I am afraid something is keeping the pump at 100% duty cycle and may burn that out!
If anyone got some insider on this, please let me know.
Thank you!
cdynaco
NW USA
Fuel cap tight?
(I had this issue on another vehicle when the attendant (Oregon) didn't put the cap on tight. The system wouldn't pressurize correctly.)
06monera96
LeShawno
Ontario, Canada
Kalatrax
Albuquerque, NM
Does it drive ok? Have you datalogged fuel pressure under cruise and load? It could definitely be a bad fuel pressure sensor.
06monera96
LeShawno
Ontario, Canada
i drove the car, hard! No miss , no bog! but it does smell of gas when i accelerate hard.
car is running a bit rich, but not enough to trigger any cel rich codes
Kalatrax
Albuquerque, NM
What do you mean it smells like gas. Out of the exhaust when you stop, or in the cab while your accelerating?
06monera96
LeShawno
Ontario, Canada
never mind looks like it was someone going rich infront of me
did not smell any type of fumes or gas today
this is what datalog told me
06monera96
LeShawno
Ontario, Canada
I notice something weird
when i clear the code I would get code
p1000 (yea that normal
p0191
p1237
Later on as i keep driving p1237 would vanish with only p0191 remaining
06monera96
LeShawno
Ontario, Canada
Well a quick update,
I replaced the fuel filter, Fuel pressure sensor @ the rail and the fuel pump driver module and the issue still continues pump is still continuously running when the key is turned on , with the engine off.
I think i'm just going to go over to ford and see what wrong.
Steedman07
Classified's Moderator:)
Connecticut
I just had the same code and it was my fuel pump. But my car would turn over, but not run at all..
