ChiDiddy
for sale is an on3 turbo kit with 3000ish miles on the kit. It sits too low on my car because i have low profile tires paired with lowering springs. I am switching out to a pro charger therefore i no longer need it. This is a complete kit. Not like the ones you buy out the box.
on3 70 mm turbo perfect condition
all hot side and cold side piping( hot side is scratched but does not effect performance)
wastegate and BOV, basically everything the standard kit has.
EXTRAS include: air filter, stainless steel oil lines with AN fitting (200 bucks for this), 39lbs injectors(250), and ford racing gapped plugs(may want to buy new ones, up to you), and pro charger add on fuel pump.
So you have about 600 dollars extra parts. Does not have a maf bung so you would need to buy that along with a tuner. Turbo ran great and i was planning on just redoing the whole hot side to keep the turbo kit but that would have costed about 1800 for me to do as quoted by a local custom fab shop. One of the pipes that go under the A arms was fabbed to fit better to allow about an inch more clearance on my car.
So for about 2600-2700 in parts, I am selling the kit for 1800 shipped. Price is pretty firm and I will remove the kit as soon as it sells. Thanks call or text if you have any questions. 7135940013 email is [email protected]
You will need to buy an extra v band clamp as I bent one while uninstalling
