So we've had our 08 Mustang for about 8 months now. It's a 4.0 V6 w/ 5 speed manual transmission. My GF drives it for the most part, and she learned to drive standard on it. So not long after we got it, she had to get a new clutch, which wasn't surprising. Well now that we've had it a while, we've had to put 2 clutches in it and the car is starting to exhibit the same signs as it did right before the last 2 went out. I've rode along with her along with a few other people, and she's shifts and drives fine. So, we've been trying to narrow down what could be wrong with the car.
This is currently the 3rd clutch.
The clutch pedal broke, and had to be replaced.
The cruise control doesn't work, I'm guessing due to the clutch sensor not be reinstalled or reinstalled correctly.
When you shift from any gear to neutral, it's as if you leave it in gear for a few seconds with the clutch and the gas released. The engine idles down for maybe 3-4 seconds, which makes me think something in then tranny is dragging.
Also, the clutch doesn't seem as it should be. It can only be 1/2 way pushed, and it will still go into gear.
Any input or advice is really appreciated as I'm just starting to learn about these cars and don't know much about transmissions.
Thanks, Matt
Thanks, Matt
