1970 style headlights
gbstang
I am looking to convert the front headlights to ducts, (there is a kit for this) I have not been able to find any conversion for the center lights (to dual beam) has anyone out there converted thier driving lights to a dual beam setup? if so how did you do this?
I have searched the forum and have not found this..
GNB
08sidewindergt
You might try getting ahold of web electric and see if they can help you. Maybe custom fab a pigtail harness?...
Charlie Sheen
Armed and Hammered
Infernum ubi sum
Agent 47? I tried doing that and running 9005 SilverStars in the driving lights with an A47 grill but I still couldn't pull off the look I was after.
Weou09
Bham, Alabama
No make the low wire low on the HID and make the high wire move the actuator on the HID(as hids dont have a high and low just a actuator that moves the bulb back and forth)
Kuro!
Banned
Austin, TX
The main problem with the look is that our headlights are a lot wider than the 70's vents were so it still looks kind of weird. I love the idea, but I havent seen it pulled off yet.
Liftedbronco
Shredder
Harrington Park, NJ
i dont understand the issue. you want high and low beams to come out of your fog lights? Check to see if anyone makes them in that bulb size. then its as simple as splicing your headlight plugs to make them have the ends that fit your fog lights.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
Because the bases and tabs are entirely different. And bulb "size" usually limits that bulb for one particular application.
