2 things
SoundGuyDave
This Space For Rent
I would ask to go on a ride-a-long with a fast driver, it should open your eyes to were you are losing time. But in the end, if your rubber isn't up to par, you won't be running near the top no matter what you do and you will likely get frustrated.
Excellent advice, and the comment about the rubber is true, as far as it goes. Stickier rubber=faster potential laps.
You can become an expert running on shit tires but when you get a sticky tire, you'll have to learn all over again, especially with R-comps. The slip angles will be completely different! Your brain and eyes will need a complete recalibration.
IF you become an "expert" running on shit tires, then you'll have gotten rid of all the bad habits (excessive control input rate, coasting, inconsistent lines, bad braking, poor vision skills), and will be able to drive the CAR to the absolute limit, consistently. If you then change up to R-comps, yes you will have an adjustment period, but you'll still apply all those skills, and will be able to max out the R-comp. If you jump into R-comps straight away, they will mask many sins, and I submit that your path to the top of the podium will be longer than if you started on "crap" tires. You will not need a "complete recalibration," since the ONLY difference will be the rate at which things are happening. You will be able to brake less, corner faster, and exit quicker. You will not, however, suddenly forget what incipient oversteer feels like, nor will the R-comps cure trailing-throttle oversteer, or alter the overall balance of the car. Once your butt gets calibrated to feel entry and apex rotation, you carry that for life. It's much easier (and cheaper!!) to do that calibration on "shitty" tires than with R-comps, which tend to be a LOT less forgiving of any sort of overdriving. If you listen to the street tires, and correlate the sound of "the limit" with what your butt feels, making the jump to R-comps is pretty simple. R-comps are essentially silent until they're going sideways or backwards. If you have no frame of reference, then that sudden shift from "in control" to "not in control" happens in a snap. Usually, literally. If you give yourself a frame of reference with the street tires, though, you'll be able to identify that subtle wiggle as "max" for the car, without looping it.
And since you can't push nearly as hard with a crappy tire, you won't learn the absurd aggression necessary to be fast in the S197 on the autocross course.
That, I couldn't disagree with more. Do you honestly think that the Autocross drivers (national level) that compete in "street tire" classes push their cars less close to the edge than those competing on R-comps? The goal of driving is to use 100% of the traction circle at all times. The ONLY difference between a street tire and an R-comp is that the sizes of the circles are different. If a "street tire" car can corner at 1.02G, and the driver hits that mark all the time, is he driving less aggressively than a driver hitting 1.4G on an "R comp" car that can take 1.6? Somehow I don't think so...
Vapour Trails
The Renaissance Man
Winnipeg, MB, Canada
Your first comment is what I'm getting at, everything will happen so much faster when you're on good tires. The reaction speed and input speed developed on poor tires will not be adequate. Time spent racing on bad tires won't be a complete "waste", but you'll still need to develop those split second actions/reactions when you move up in grip. Again, track and autocross are very different with regard to the rate of driver inputs. I'd guess there are more inputs in one lap of autocross than several laps of a road course, and those inputs during autocross will at a frantic rate. Actions on a road course seem more measured, thoughtful and smooth. I totally agree with you regarding street tires giving more feedback, but in autox you may never have time to react to it.
I'll attempt an analogy, you could practice hitting baseballs thrown at 50 mph all day long until you were an expert at it, hitting home runs every second ball. But when you step up to the plate against a pitcher throwing at 90 mph, you'll strike out everytime. The reaction speeds developed at 50 mph just won't be up to par. When you move up from baragin basement chinese tires to A6s, you'll be under-driving the car for some time until your skills match the tires.
Second point; what I said applies more to someone starting out. I had no clue how aggressive a driver needs to be until I rode along with a good one on grippy tires. Knowing what a car feels like when it's using 100% of it's potential is really helpful when starting out. In the absence of such a ride, it might take a driver awhile to find out it feels like, especially when their lack of grip makes them nervous. When talking about national level drivers who have likely driven extensively on both kinds of tires, the situation changes quite a bit.
In the end, I can only offer my own experience driving on both types of tires. I started autocrossing on 235/55/17 stock tires. I improved a bit, but also experienced a lot of frustration having to go slowly in order to say, not experience mind-blogging understeer in a especially tight section. As things progressed, it became apparent that the tires were holding me back from developing the driver speed&reaction time because I had to drive much slower than my competitors. I was at the back of the pack with Honda Civics and Focuses that had better tires. Consoling yourself with the knowledge you are ridding yourself of bad habits and learning the right way while the guy who borrowed his moms civic and threw on sticky tires is handling you your ass won't go far, trust me.
Had I continued on that path, I feel I would have become very good at driving with minimal grip, but I would still be slow.
Near the end of my first season I bought a set of used R-comps. The first couple events with them I was seriously underdriving, but that was fine and it was great to have the chassis respond to my inputs rather than plowing worse than a sled loaded with presents and St.Nick. Something to note here is that you don't have to spend a serious amount of money to move to Rs. There are used tires for sale at the SCCA forums, for less than half of the new price. I bought a set of Rs and rims for $700, less than just about any cheap set of street tires. If the grip of them new was 10/10, these were probably an 8/10, but still better than almost any street tire money can buy.
Anyway, by midseason of the next year something strange was happening, I had moved up to the top 20-30% of my club, from the bottom 20% the previous season. People were commenting that I was getting much better and I was having a lot more fun.
I would go on further, but I'm going to get fired.
SoundGuyDave
This Space For Rent
I know it's a semantic difference, but I'd like to concentrate on the concept of "frantic" for a second. First, I will stipulate that an average autocross run will have more control inputs than a lap at a "normal" road course (excepting possibly The Nurburgring!). I will also stipulate that because the corner radii involved are tiny in comparison, input rates, the time spent actually making a specific brake, gas or wheel input, will be higher. What they aren't, or at least shouldn't be, is frantic! Take a look at any of Sam Strano's in-car videos, and you'll see what I mean. Nowhere does he "slam" on the brakes or gas, nor does he "yank" the wheel over frantically. Again, it's a semantic difference, but to me, at least, it's an important distinction, one that I will come back to later.
Excellent analogy! If, however, you spent your time in the 50mph batting cage concentrating on perfecting the perfect swing... Not pulling the bat back or wiggling it before starting the actual swing, not dropping your rear shoulder under the swing, finding the right stride length, etc... If you then walk into the 90mph cage, you'll have an adjustment period, but once you find the new rhythm, you WILL be out-driving the people that started there but have poor techniqe. There's a reason that the Skip Barber cars use street rubber and not slicks...
That point, however, has no bearing on whether to start on street tires or not. Finding the correct amount of "aggression" is important, but THAT lesson can come on any type of rubber. Once you get the whole concept of "slip angle", it simply becomes a matter of analyzing the tire's behaviour to determine the proper amount to input. Race tires demand a higher slip angle for maximum traction than street tires do, but give none of the audible feedback as you start to approach that point. They tend to simply grip, grip, grip, and then you spin or plow, unless you know the subtleties of how a tire feels as it reaches and then exceeds the proper slip angle.
Given that the S197 chassis, in stock form, DOES tend to plow a bit (understatement!), that type of understeer can also be induced by too rapid a rate of control input from braking and/or steering wheel. This is going to come back to the "slow down to go faster" school of thought. If you were to slow down your rate of wheel input to allow the tires time to bite and start to turn the car, you may be able to get through that section quicker. Neat experiment: Next time it rains (sorry left-coasters, since you have permanent sun, you can't do this!) or snows, take your car out into a large flat parking lot, and get up to a nominal speed, say 25mph or so, and make a 90* wheel movement to the left, maintaining the same throttle input. Do so first with a target of 1/2 second to go from straight to 90*. The car will push a little bit, but will arc around the corner. Now, in the same spot, and at the same speed, make the same turn, but this time target 1/4 second to make the same wheel rotation. I bet the car will plow on dead straight for a bit, bleeding speed, and then snap over into the turn. Now, think about the same concept on an AutoX course. Too quick of a control input rate will cause you to understeer on entry. Too high of a speed will cause you to understeer on entry. In the same parking lot as earlier, I would bet that you can find a rate-of-change-of-control-input (call it "control rate") that will yield the quickest turning rate (smallest radius) for a given speed. The car is still going to push, however, but not as badly as with a "frantic" control rate. Simply changing tire compounds will not change any of the behaviours of the car. If it pushes on street rubber, it will still push on R-comps. If it's loose exiting a corner, it will still be loose on R-comps. All that will change will be the vehicle speed. What that means is that to get maximum exit speed from a given corner, you will still have to brake, turn in, apex, throttle up, and track out right at the adhesion limit of the tire on the car. If the street tire can take a given corner at 30mph, and you can learn to run it at 29.5mph consitently, do you think you are performing better or worse than taking the same corner on R-comps, which can be done at 42mph, but you're taking it at 38mph? On one hand, no, because you're going 12.5mph FASTER on R-comps, but on the other hand yes, because you're using 98% of the tractive capability of the car on street tires, but only 90% of the tractive capability of the R-comp. I will submit that if you can perfect your techniques on the street tire, and then transition to an R-comp, you will be much faster, more quickly, than trying to do it all at once on R-comps, simply because there is such a steep learning curve to them.
In the end, the stock S197 is still a hippo wearing a tutu, and pushes like a pig! Tight sections of track will always be problematic for ANY car weighing the best part of two tons when compared to a car that may well weigh under a ton. At one event, I paddocked with a pair of Lotus Exige who I overheard discussing a weight variance between them of 100 lbs, at 1750 and 1850lbs. I blurted out that my Mustang weighed more than BOTH of their cars combined...
I will agree with the premise, but not the reasoning. It's the experience factor. Any idiot can (and sometimes does) bolt on a set of A6s and screams "Look at me, Ma! Top of the world!" That does NOT make them a better driver than somebody who took a methodical approach to developing technique before speed. Bad habits are VERY hard to overcome, once engrained. At first, the driver that comes screaming into a corner with the brakes on fire, snaps the wheel over and lets the car push in towards apex, and then lights up the rears on the way out, fishtailing like an out-take from The Dukes Of Hazard will be the envy of every other guy at the track. Look how fast he is!! Then another guy, with proper technique is going to go through, and nobody is going to give him a second look since the run was so boring. Until the times come up, and he's a second or two (or more!) faster, because he's not wasting any energy. I would personally rather be the second guy, then make the jump to R-comps, than the first guy who's already on them.
True, depending on how you're approaching your sport. If you're out there for kicks, then yes that's frustrating. If you're out there to learn how to drive, then it's a different matter. If you drive with fists of ham, throwing a bunch of transients at the R-comp tires that spike them to the edge of the traction circle, you'll never learn how to trail-brake. If you're mister smooth, and learn how to trail-brake, and see your run times drop a full second or two, you will still be smiling as you cinch 8th place, knowing that after an event or two on R-comps to get them figured out, you will be handing these bozos their asses by a HUGE margin...
And here, we come to the crux of the matter! I will submit that YOU will not be slow, you car will be, due to the comparatively poor grip and smaller traction circle available to exploit. I think it would be better said: "Had I continued on that path, I feel I would have become very good at driving." Once you become "very good at driving" it becomes simple to make the transition to race rubber, and you will catapult yourself into not the top 20 or 30%, but the top 10%. There will always be an "alien" that is just an idiot savant (Yeah, I'm an excellent driver...) at it, that just has that internal whatever that separates you or me from Micheal Schumaker or Mikka Hakkinen. Driving skill will always win out. I would be willing to bet that if you took your car on race rubber you would be SLOWER than Boris Said in your car on street rubber. He uses 100% (or more!) of the available grip AT ALL TIMES, and I would be willing to bet you (and me, and 99% of the rest of us) use nowhere NEAR that amount. He has none of the bad habits that we do, and will be plain faster as a result. This is not drag racing, where the guy with the most money wins.
All that means to me is that you weren't loading up the R-comps like you were the street tires. Refer back to my 98% versus 90% argument earlier... A compound change will NOT alter the behavior of the chassis. It will only change the maximum net grip available. Understeer is caused by using too much of the available grip to slow the car, and not enough to turn it. R compounds simply do the same thing, but at a higher speed. If you pushed with street tires, you were overdriving the car. If you then did NOT push with the R-comps, you were underdriving the car. One of the biggest stumbling blocks with learning on R-comp tires is that they are so unforgiving at the limit, and there is little warning of what is to come with them. With a street tire, they're squealing, then squalling, then howling, and (in this case) they push, then push worse, then just skid straight. R comps are silent, then silent, then there's a hint of "grumble" then they go silent again, and they grip, and grip, and grip and then just let go completely. If you learned on street tires, you can equate that line between squalling and howling to the grumble, and you'll know what comes next and how to handle it. If you started on R-comps, you're more likely to under-utilize them to avoid punting cones or flying off the track.
In the end, I think it comes down to the approach to driving. If you want to be the best possible driver, approach your learning in a methodical, logical progression, and move on to the next item ONLY after you have mastered the previous one(s). It's only once you start "feeling" the weight of the car transitioning around when you're just driving to the corner store for a soda that you really understand weight transfer and the impact it has on the chassis. Same thing for judging surface conditions and corner types (concrete vs. asphalt, on-camber/flat/off-camber; increasing/constant/decreasing radius, impact of elevation changes on control inputs, etc.). Once you get a handle on vehicle dynamics, to the point where it's second nature, then you start working on techniques. Braking, throttle, steering, trail-braking, left-foot braking, heel-toe, eliminating coast periods. Once you master those flawlessly, I guarantee that you will be on the podium given even rough parity between the competing cars.
Don't do that!! I'm having too much fun arguing with you! Fire back when you get home!
Cookiemonster
In your cookie jar
such an entertaining thread (and informative)
Me and my buddy are just starting out with autocross (both been to 5 events and a SCCA school) Hes in a bone stock V6 mustang with with Rcomps and im in a bone stock GT with NT555s and were within tenths of a second of eachother. Kind of an interesting match up of an over tired under powerd car vs an over powerd under tired car.
pieperz06
i need to get blown
Corpus Christi,TX
damn i love how the coner carving part of this forum has become less of a teck thing and more of a technique thing
i want to hear a discussion of tire's now lol
SoundGuyDave
This Space For Rent
When you talk about drag racing, it pretty much boils down to the biggest checkbook wins. Absolutely not so on the road course, or an AutoX track. There, it's primarily technique based. In NASA Midwest, there was a TTC car that was faster than ALL of the TTB cars, half of the TTA cars, and within a few thousandths of the TTU cars. That kid can DRIVE!!! Yes, a Honda S2000 was beating up on Mustangs, Evo IXs, M3s, C6Z06s, and a 911 Cup car. On a 10-turn 1.7 mile course... Outstanding behind the wheel.
Well, the best ones are pretty much round, but with a slight bulge at the bottom... But that's only my opinion!
RedMosesSC
NYC
Its great how the Road course/Autox guys not only want to share knowledge and experience but are also very passionate about posting, you rarely see this level of detail in other forums.
pieperz06
i need to get blown
Corpus Christi,TX
back to my OP i freekin love the D specs they made a big difference the car feels way confident in turns i have it at 2 turns in the front and 3 in the rear from full stiff
RedMosesSC
NYC
That seems to be the best config on the track for me as well, although lately ive been goin more stiff in the front. Nice thing about the D Specs is you can adjust quickly, so changing settings in between heats is no sweat. Ill usually adjust the setting in the 1st 2 or 3 runs or keep whatever i started with as long as the car feels compliant.
I think its better to work on driving corrections than tweaking the car. It helps to get to know some of the regulars at these events, what i find is know that they know me, they will talk to me in between heats and point out where they saw me loosing time and suggest corrections, this ALWAYS helps me improve on my time.
SoundGuyDave
This Space For Rent
Hmmm.... Another case made for technique (proper line in this case) over hardware for best lap times...
Kaldar142
Silver Spring, MD
In both my WRX and my mustang i dont even adjust the suspension/tire pressures but rather just work on driving technique as well
