2006 coupe 10 second NA street/strip
gil_t2
Love Nitro in the Morning
Northern Va
train is fresh. Rebuilt trans PA parts. Engine fresh just some break in runs. Needs Adjustment to tune. Car ran 10.86 in a test and tune. 1.4 60 foot. I changed intake and never got a chance to adjust the tune and test after that. Medical problems are reason for sale. Way too many parts to list car is Streetable. Price is 18,000
car is still available open to any offer in to get it goine
Awesome N/A build. What parts do you have on it apart from the obvious ones in the pic (JLT 3 CAI, JPC intake manifold)?
Any weight reduction?
Have you run it on the dyno?
A curious mind would like to know. ;)
gil_t2
Northern Va
Have not Dino the car. Was going to do it after retune. Parts 5.4 iron block .20 over. Stage 3/3 valve heads forged internals all balanced everything you can do. Car has had some weight reduction but no full passes after weight reduction. Race craft tubular K member. one piece aluminum driveshaft,Strange adjustable coil overs on front ,QA shocks on rear BMR suspension pieces. has cobra jet master cylinder and brake pedals, aluminum fuel rail and filter system. BMR suspension pieces 4.30 gears true track posit unit, runs on E 85 has a roll bar light weight seat.
3 inch stainless steel exhaust hooker headers, trans mission aluminum servos not installed. JPC front bumper brace, steering wheel and release hub battery move to the rear. Oil filter relocation kit torque box reinforcements, Eibach rear drag springs Aluminum DEF cover
Engine build post on this form by Spyder7724
gil_t2
Northern Va
Yes I still have the car and plan on running it this summer if I don’t sell it
Sammy70
How "streetable" is it? I realize that's a relative term and "streetable" means different things to different folks :)
Where is the car located?
gil_t2
Northern Va
It’s still has heat and air conditioning drives real nice current tune has overdrive turned off so with for 30 years it’s a little steep. I know airbags has roll bar everything it needs to be NHRA compliant not really a daily driver but a nice car to maybe cruise to a show or drive to the race track located in Winchester Virginia
gil_t2
Northern Va
runs on 85 can be re-tuned for gasoline and no airbags still has heat and air conditioning working current to overdrive turned off ABS turned off those can usually be turned back on. Car is comfortable to drive very noisy loop
gil_t2
Northern Va
This car is still available has been kept in heating air condition garage because of medical problems. I have not done anything with the car still in as listed condition.
gil_t2
Northern Va
This is a great car I need to get rid of it. I am open to any kind of a reasonable offer engine cost 20 grand transmission cost 4000.
