Current goals for the car:
-1000 real deal HP on e85. This is 1000 all the time, not some 3sec hero run on the dyno under perfect conditions. 1000hp all the time.
-Still able to drive it at the road race track with no cooling issues.
-Still able to drive it on the street, sit in traffic if I need to, etc.
-220+mph in the standing mile.
-Not embarrassed to show people the car because the fit and finish is not up to my standards.
-Reliable.
This years Plans:
This is really the first time putting pen to paper, this list may get silly.
-Completely new e85 fuel system front to back, every single part. Fore triple pump hat with one 340 and two 465’s. Fore pump controller, Fore regulator, Fore rails. I got the Fore stuff from Jeremy at S&H (thanks man!). Super nice stuff, I’ll post pics soon. I haven’t gotten PTFE (e85 safe) lines yet because I haven’t decided what I want to use. It will be fabric/Kevlar line though. I’ll never do stainless again. Injectors are still up in the air too, haven’t decided what I want to use yet.
-The IC system is getting another do-over. It’s all plumbed with 3/4" line right now. I’m gauging it up to 1.25” all the way through. This is a HUGE deal. The HE’s need to be removed, the fittings need to be cut out of them and then 1.25” fittings welded in. A lot of the stuff around the HE’s will have to be modded to clear the big fittings. The expansion tank will need to be modded at the least and maybe completely re-done. And this time instead of running the lines to the rear HE under the car they are going right through the cabin with bulkhead connectors at the firewall and the rear bulkhead. I will make it pretty though. I’m looking to go from my estimated 6gpm of water flow to somewhere in the 20gpm range. It’s going to suck though, 1.25” fittings are HUGE! It is going to be stuffing 10lb of shit into 5lb buckets most of the time. And of course 1.25” stuff is not cheap!
-I’ll be running the first Gen III R-Spec manifold which is in process right now.
-I’m going to put bigger cams in, not sure which ones. Either 550’s or some sort of custom grind. I may need valve springs too. They will be locked out with a V-10 conversion.
-The rear control arms are getting upgraded to BMR “solids” because race car. I’m sick of messing with other control arms. I need some race car stuff back there. The control arms are already here (thanks Kelly!), and are beefy! I’m waiting on fasteners. I ordered some big daddy 10.9 zinc plated jobbies to replace all of the factory TTY stuff. I have had a clunk back there that has been driving me nuts, so I’m putting a stop to all that crap. I went so far as to have Alex spin me out some stainless spacers/bushings that take up the slop between the bolt and mount in a few spots. This clunking crap is going to stop right now.
-I’m going to finally stop drawing crankcase air through the blower and instead run “breathers”. But I’m going to run a Steff’s tank/catch can which will be fed by a -12 coming off of each valve cover.
-I’m finally going to finish the rear diffuser.
-I’m going to cut a new front splitter (identical to the one on there) because the one on there is crappy looking around the edges. Then paint it with some bed liner (light coat).
-I’m finally going to install the trans and diff coolers.
-I’m not doing a wire tuck yet, but I will be cleaning a lot of the wiring up.
-I’m going to finally finish trimming out the rear seat area. After the roll bar went in and the rear bulkhead I didn’t do anything with it, it looks like crap.
-We’re cutting the stock T-56 Magnum shifter up and then putting an arm on it that is not rubber isolated (that drives me crazy!!!).
Pretty stuff:
-Powdercoat front cover and valve covers in wrinkle black.
-Powdercoat the aluminum tanks under the hood wrinkle black.
-Anodize intake manifold red.
-Anodize the belt kit and brackets in black and red.
-Maybe anodize the TB red.
-Fix/paint the firewall.
Stuff I want to do:
-I would like to put a newer/bigger AIM dash in it if I have the $$$. I probably won’t.
-I would like to run the new SCT Livewire TS thing if I have the $$$, I probably won’t.
-I would like to put a Tiger Racing hood on it if I have the $$$$, I probably won’t.
Well, that’s all the big stuff. There are about 10,000 small details that need to be addressed though. I’ll be taking more pics this time around.
