Looking good Terry
Amazing car
Nick,
I Thank-You Sir.
Well you know I am going to be "Biased" but I think it is .........
Terry.....the tigermachine looks good, not usually a fan of 20" wheels but they look great on your ride. Puzzles me as to why people continue to get on these forums and either bash people or puff their chest out thinking they are something great. I appreciate the way you respond back to those posts. Thanks for posting the jesel information and the cam info for our 3V's. I do have a question about the TCI transmission, I realize that you have not driven the car very much since the swap but what are your thoughts on the transmission?
Mike,
Actually I went with the 20" so I was for sure the new Roush Trak-Pak 6-Piston racing brakes would clear.
http://www.brenspeed.com/403144.html
As it has turned out the 20" M/T wheels & tires look OK on the Bullitt.
I was looking for a name that went back to the earlier years of the Muscle Cars.
The M/T, (Mickey Thompson) name goes way-way back so I went with them.
I have also went with the M/T tires for the same reason and also to match up with the M/T wheels.
Plus the M/T tires work very well for the street in most cases.
(They are not IMHO a Drag-Race tire)
You know what there could probably be books written on why people say what they do on the INTERNET.
I think what possibly brings out the negative comments in general are people that post to people that they know they will never-ever see in person.
And of course there are those that think if they jump on the Band-Wagon when all the Bad-Asses jump on a member they will be part of the, In-Group.
Just to say something here on me and what I initially thought the Internet Mustang Sites were about,
I actually thought in the beginning they were about Guys or Gals wanting to talk and discuss their Mustangs with other Mustang enthusiast,
Man what a Naïve person I was back in the beginning on the Internet and Mustang Sites.
Because .......
In some cases, Thank Goodness, there are those adults that do actually talk and discuss in an adult manner.
But ........
Way to often there are those that jump on a person's Thread/Post and just simply wear that person out with No-Mercy.
So in conclusion to what you said here is where I stand when I can posting to others.
I try to still be polite to the Dick-Heads and at least come back to those with a reply that makes sense.
Probably not what they want to see but at least I do try to give it a try.
This is going to take some typing buddy and I sure am not a typist at all.
In this case I will try to cover a few areas factually as I have knowledge of.
I will be talking about the, TCI Super Street Fighter tranny.
In my case also I run it with the, Circle-D custom billet converter.
Plus it is "Tuned" by Brent White the owner of BRENSPEED.
{The Tune IMHO is the Major ingredient to it lasting}
I have not as you know driven it with these last set of Up-Grades.
But I have driven it for a few years as it was done the last 1/4 of 2011.
True not with the last set but I have put thousands of miles on it.
It has been raced multiple times at different Drag-Strips.
Some with Brenspeed testing it and multiple times me driving it.
You know maybe the better approach to what you really want to know would be for just talking to you.
Meaning just as if I was talking to you in person.
That's my preferred method of posting anyway.
You ask for the truth so here is what I think,
I have had (Zero) problems with mine over the years since 2011 when it was installed.
But ........
I don't drive it like some 20 year old that Daddy bought it for me with his dollars.
I try my best to use at least some common-sense when driving it with the auto.
Here is what I know, (Not) to do !!!
Be driving it in 5th gear overdrive and instantly Floor-it.
That is for sure one thing that will, (Destroy) it on the street.
(I'm referring to the High H/P cars above with tons of Torque)
The way to run it is simple as 1st, (Assuming you have the TCI Ratchet Shifter I do) push the Btn. on the TCI and let it go back to 4th gear.
Push down on the go-pedal, (Don't floor it) and get it to drop back like in 3rd gear and then Floor-it.
At 50/60 MPH it ain't gonna shift back to 2nd gear at those speeds with either the 3:73 or 4:10 gears.
I'm now running the FRPP complete Shelby GT-500 rear-end-assembly it comes with 3:73 gears.
So if you can follow the above Guide-Line more than likely the TCI will last awhile.
Next, if you are on the Street or Drag-Strip and Stopped ..........
Simply push the TCI Btn. so it locks out 5th gear/overdrive and take-off with it in "Drive".
If you have a Custom-Tune from a reliable Tuner that has actually raced with the TCI what I have said should work just fine.
(The tune does not have to be from Brent at Brenspeed but he is one person that does know how to do it)
What else .......
Don't ever take off Wide-Open Throttle and if it gets Crazy so you let out of it, NEVER-EVER then Slam it back instantly back on the Floor.
If you do that many times I can assure you the TCI will definitely sooner or later [BRAKE] !!!
You know as I sit here and think about what you and anyone else reading this would really want to know different things come to me.
Read carefully below what I say .....
Once we modify our Mustangs way past what the factory power was.
And we jump in and change over to like the TCI Super-Street-Fighter Transmission.
And by all means don't Cheap-Out on the Converter !!!
Circle-D is an excellent choice and what I run.
Keep in mind a Stock Mustang with it's auto tranny you can just screw around with it pretty much any ole way you want.
But, up the H/P to around 500 and also the Torque, (Which Kills Tranny's) and you no-longer can just do as you please.
You now have to, (Think) before you just Floor-it every time you turn around.
Or driving down the interstate and a guy/gal pulls up beside you and you just instantly Floor-it and the TCI has to shift down maybe multiple gears.
According to just how built your engine is hooked to that TCI SSF is going to probably be how many times you can get away with that.
Here is a statement that very well might just have You and many others Jaws Drop,
in some ways to be honest it is more fun driving these Mustangs before we get so crazy with the POWER.
Well, you didn't ask me about which was more fun so back to the TCI.
I know for sure a friend of mine that raced in the NMRA as well as the NHRA was having to Overhaul/Rebuild his TCI SSF Trans every year.
It will not hold up to racing it all the time just so you know.
That's one of the reasons I limit racing it so much.
It just simply will (Not-take-Constant-Abuse) !!!
He is changing over to the 4-Speed Auto which is a much beefier trans.
A quick Recap,
I like what I have and intend on keeping the 5R55s TCI SSF & Circle-D converter set-up.
I know what to do and not to do and hopefully I have said those things plain enough above for anyone else to understand.
Just keep in mind if you are running the same TCI etc. I am and you have around 500 HP & Trq. use common-sense or the TCI will BREAK.
If you have anymore questions jump on here and ask and I will at least make the effort to answer you factually.
Terry
