Mach Silver
I'm not sure but I think the Ford transmissions now require a special tool or fitting that you screw into the drain plug to fill them. Pretty much a dealer only item or a good shop that specializes in transmissions. I was going to suggest just changing the fluid but ford doesn't allow it to be that easy.
Therefore the next best option would be to buy an aftermarket pan with a dipstick, filter and fluid. Change it yourself and put a real pan on it with a real dipstick. Or pay a dealership several hundred dollars to change the fluid for you and still not be able to check it.
Another option might be to run it by the dealership where you bought it. Depending on the integrity of the dealer you might at least get a fluid and filter change out of the deal. I hope it's nothing more serious.
You can get the fill plug from Amazon for 11 to 15 bucks its made I think by OTC im ordering one myself.
Just bought this 2010 auto gt monday. Has 80k miles .... I thought about going for a newer coyote 5.0 but always wanted this body style and own a couple 2v 4.6's that i always wanted to mod in my vics but never could because theres not really much for tunes for vics etc..... So figured id get the body style i wanted and be able to do the 4.6 modding ive wanted to do.
Anyway, i got this 2010 gt and been running/shifting fine since I got it monday. On the way to work im grannying it and when it shifted from second to third rpms jumped from about 2k to 2.5k and then it grabbed. Happened 2 more times on way home from work at cruising speeds.
My work is only a mile or so from home so if it was low on fluid would it do this so soon before warming up?
Doesnt do it if I get on it just when cruising. Ive worked on cars/motors my whole life but never been a transmission guy so dont know whats going on. Not sure if its slipping or just engaging sluggishly.
I see theres no dipstick on these (why ford?) and dont have a lift and not putting it on stands just to check fluid.
Supposedly dealer checked or replaced all fluids but maybe they didnt have it to temp I dont know. Probably the reason the last owner traded it in.
This really sucks .... They wanted $14,500 but got out of there at $13,500 which is still close to what I could of got a early coyote with 50-100k miles for.
I was going to order sct tuner and start ordering headers/exhaust but now have this to deal with.
Any easy driveway method of checking fluid? The one good trans shop we had that didnt rape customers is closed now and dont trust the other shops around here but not a trans expert either..... Ive replaced filters/seals and dropped/installed trannys but thats the extent of it.
so what do you guys suggest? Whats likely going on ? Im pretty bummed
I have found some good resources on this issue and its pretty common for the 5R55S and W. To check the fluid you need an Allen wrench to reach up in the middle of the oil pan to pull a plug then you fill the transmission with the fill plug you can get off of amazon for 11-15 bucks. But the real bummer is the solenoid issue. There are repair kits for them and you dont have to pull the transmission but you need a good torqure wrench and be mechanicaly maybe a bit more then just changing plugs in your car. I have this problem right now with mine. I have installed shift kits and done basic service on other transmissions so I think I can tackle this. But its important to catch it fast from what I am told because it can cause more costly damage if you keep driving it, like I have been doing. Speed up let off the gas and give it a second an it shifts to 4th and skips 3rd. Works better with OD off too.
Here is the fill tool this one is 11 bucks
A filter change and flush won't hurt but be aware it is not a full fluid change. Only partial. About 5 quarts out of the 11.8 it takes.
There is a possible way to change all the fluid without going to the dealer, but it is involved.
Drop the pan and change the filter. Refill the missing fluid. This fluid will also get changed.
You will need:
Two clean 5 gallon buckets.
A 12 foot (or so) length of clear tube cut into two pieces.
14-15 quarts of your favorite fluid. Will explain why the extra in a moment.
Jack the car up off the ground as high as you can. Use jack stands.
A trusted friend to help.
Someplace on the trans is an output to feed fluid to a cooler and another place to return it into the trans. You disconnect (or tap into) the output between the output and the cooler and connect a tube to one of the buckets to act as a collection bucket.
The other tube is connected to the line headed to the cooler (or the inlet port) and is dropped down into the bottom of the feed bucket. Fill this bucket with all the new fluid. All of it.
With your friend watching the buckets....
Start the car and run it through the gears several times. As the trans runs it will pump the old fluid out into the collection bucket while drawing the new fluid out of the feed bucket.
Here's the part about why to have the extra quarts.
As the trans draws the fluid in from the feed bucket you run the collection bucket past the 12 quart (3 gallons) mark to make sure you changed all the old fluid out. If the old fluid has a different color, watch for it to change to the new/fresh color.
You should be done before the bucket of new fluid runs dry. And your friend should help you know when to stop.
If you put an aftermarket extra capacity pan adjust the number of quarts accordingly.
This should change all the fluid in the trans and also the convertor. I think the 5R55S fluid path is internal so the convertor fluid is continually flowed through the filter with the fluid in the rest of the transmission.
I have not done this, but read about it and plan to do it to my F150.
I was wondering how this would work, because when I worked at a shop that flushed they had a machine but i often wondered if you could do it this way too. Thank You ... Ill bet it can be messy, Im sure it will be for me...lol
