SoundGuyDave
This Space For Rent
- Joined
- Apr 9, 2007
- Posts
- 1,978
- Reaction score
- 28
No aero expert here, either, but...
UHMW is VERY dense stuff, with pretty significant weight in a large sheet. If I could be so bold as to recommend, think about doing a separate splitter blade and undertray. Make the undertray out of something light, like boxed sheet aluminum, and save the material weight and expense. As long as the joint between the blade and tray is smooth, the air really doesn't car what material is used. Also, when (not if, but when) the splitter gets destroyed on a berm or in an off, it's potentially easier and cheaper to replace just the exposed blade portion. When designing your mounting system, make sure you incorporate some form of sacrificial component in the mount, and carry spares with you.
Also, if you're going to pay the "non BTM aero penalty," make sure you get your "money's worth" out of it. Splitter, wing, diffuser, cunards, spats, etc all "cost" the same as an OE option rear decklid spoiler. In for a penny, in for a pound? Unless you have a lot of tracks with loooonnnngggg straights or a lot of relatively high-speed corners, you MAY find that you will be quicker overall simply carrying less weight.
No evidence, but just food for thought.
