So I have decided to switch to a return style fuel system on my rebuild. I have been given conflicting information from various tuners and manufacturers of these fuel systems.
Scenario 1.
Install Return Style Fuel System like how the instructions say, which is to install new hat/return style pumps into the tank and disable the FPDM's in the tune and just ltrigger off the fpdm's with a relay and let the regulator on the line do its work. These seems to be the easiest scenario.
Scenario 2.
I am being told that my year 2012, lacks the ability to tune out some of the trouble codes of bypassing the FPDM and having a return style pump run 100% of the time (like how they are designed) whch could cause issues like crank relearns etc.
So it was recommended that I install a return line and regulator like a return style system, as well as a new hat with larger pumps but maintain the FPDM's and just upgrade their wiring, as in run a wire from the battery straight to both FPDM's then upgrade the wiring to the hat. This second scenario requires zero tuning adjustments. This seems like a "hack" or a "trick" to the returnless system.
Thoughts?
Scenario 1.
Scenario 2.
Thoughts?
