2012 Mustang gt VCT not engaging
Fartboxer
Hello,
I have found surprisingly little info on issues with the vCT for 2011+ 5.0L mustangs so I thought I may ask here. I have a 2012 mustang gt with about 115K since new. There is a BAMA street tune and intake for the past 100K miles. Just recently when accelerating hard at 4K when the VCT is normally engaging it feels like its half engaging and I have less power then before. I did a few pulls to confirm it was pretty consistent in every gear and parked the car. My concern is eating the timing chain and everything going boom.
Based on the info I was able to find first step seems to be to change the oil as older oil may gunk it up and cause this so thats on for Saturday. I checked the oil recently and it was fine and I always do it myself. It was done about 6K miles ago which is longer then I typically wait. The only other thing I can think of is the actuator solenoids for the VVT system. I have ordered 4 from CJ pony parts (nobody stocks them) that fingers crossed I will get on Saturday. If the oil change doesn't work then I will change those.
So few questions.
Is my logic here sound? am I missing anything? My understanding is there is no fuel filter and the car is fine unless the vvt tries to engage.
How obnoxious will changing the sensors be? I understand I need to remove the valve covers? anything unusual to watch for or any youtube videos to help? I have always worked on cars and am an engineer for a Ford supplier so I know I can handle it, but you never know what kinda crazy it may turn into.
Thanks for any help.
Vtec yo
dark steed
Resident noob
Winder, GA
Its possible that the VCT filters are clogged. There is 4 of them.
I think this was a troll or a scammer post. There were about 10 or 12 links on the end of his posts that I wouldn’t click on. I reported it and they were removed. The dude has only made one post ever, this one.
Fartboxer
I am not a troll and I did not include any links in the bottom. Just don't wanna blow my car up.
dark steed
Resident noob
Winder, GA
@stkjock
Was I just seeing things? Someone removed all that garbage at the end of the post after I reported it.
Btw, vtec yo isn’t gonna endear you to many here lol
You must have a weird sense of humor to choose a username like Fartboxer. ;) Anyway, welcome to the forum.
Every car has a fuel filter so I suggest you replace yours. Other simple things you can do is to replace the spark plugs, engine oil/filter, clean the throttle body, and clean the MAF sensor.
Malfunctioning VCT solenoids will throw fault codes so I suggest you scan the ECU, report the results, and we can go from there.
