Making a list here. Will have more parts soon - just needed to start keeping track!
OEM Front Subframe (K-Member): 58.2lbs
BMR Street/Handling K-Member:
BMR Drag K-Member:
OEM Rear IRS Subframe (Empty): 55lbs
OEM EPAS Rack: 36.46lbs
OEM Motor Mounts: 3.9lbs - each
OEM Rear Lower Seat Cushion: 11lbs
OEM Windshield Washer Fluid Res. w/ Fluid: 9lbs
OEM Battery: 31.31lbs
Deka ETX18 - 17.67lbs
OEM Catback Exhaust: 72lbs
Magnaflow Comp CB - 44lbs
OEM Base 18" GT Wheel w/ Tire: 54.5lbs
OEM PP Model 19" GT Wheel w/ Tire: F-60.6lbs / R-64.3lbs
Billet Specialties 17x4.5 w/ MT SR 28" Radial - 39.8lbs
Billet Specialties 17x9.5 w/ MT 28" Drag Radial - 51lbs
OEM GT Cloth Seat: 50lbs
Corbeau FX1 w/ Bracket - 21.7lbs
OEM "Mid Pipes" w/ Cats: 22lbs
MAK O/R Pipes -
OEM GT Base 14" Front Brake Kit (Rotor/Caliper/Pads) - 43.8lbs per side (87.6lbs total L+R)
OEM GT PP 15" Front Brake Kit (Rotor/Caliper/Pads): - 47.2lbs per side (94.4lbs total L+R)
Aerospace 13" Lightweight Street Brakes (Rotor/Caliper/Pads/Brackets) - 19.4lbs per side (38.8lbs total L/R)
OEM GT 14" Base Front Rotor: 28.56lbs (57.12lbs pair)
OEM GT PP 15" Front Rotor: 33.4lbs (66.8lbs pair)
Aerospace 13" Lightweight Street Rotor - 14.3lbs (28.6lbs pair)
OEM GT Base Front Caliper: 15.24lbs
OEM GT PP Front Caliper: 13.8lbs
Aerospace Lightweight Front Caliper - 5.1lbs (10.2lbs pair)
OEM Front Sway Bar: 12.7lbs
OEM Front Sway Bar End Links: 1.6lbs pair
OEM 2-Piece Driveshaft / Auto: 29lbs
OEM 2-Piece Driveshaft / Manual: 36.2lbs
Shaftmasters 1-Piece Aluminum DS - 19lbs
OEM IRS Halfshafts: 21.1lbs/each
FRPP Halfshafts: 30.2lbs/each
OEM Front Spindle/Hub Assembly: 19.3lbs each
OEM Front Control Arm: 4.3lbs each
OEM Front Radius Arm: 6.8lbs each
OEM Front Tie Rod: 2lbs each
OEM Tire Air Pump: 5lbs
OEM EVAP Module/Canister
OEM Engine Sound Tube: 1.3lbs
OEM Engine Coil Covers: .75lbs/each
OEM Engine Cover: 3.4lbs
OEM Battery Cover: 1.23lbs
OEM Plastic Trunk Latch Cover: 2.40lbs
OEM Rear Seats: 30.8lbs
OEM Trunk Carpet Cover: 4.6 pounds.
OEM Stock Floor Mats: 2.6 pounds.
2015 Mustang GT Performance Pack 300A - MT82 Transmission
Curb Weight (scaled at BMR) - 3736lbs
Front Unsprung Weight: 143.9lbs per side
Rear Unsprung Weight: 132lbs per side
2015 Mustang GT Base 300A - 6R80 Automatic Transmission
Curb Weight (scaled at BMR) - 3704lbs
BMR Drag K-Member:
MAK O/R Pipes -
