lito
Disgusting and embarrassing. 30,000 miles.
Sent from my Nexus 9 using Tapatalk
2010 explorer I went to check because of 'PCM issues'.Who's engine does it belong to ? It appears the oil has never been changed since day 1.
As in 2-3 months of labor. Sad.as in 2 or 3 days of labor? Man.
I make a lot of money I guess. Sort of.
All I know is if my trusted shop wasn't changing the oil and I ended up with that under the covers I would be pulling some liveleak Brazilian off duty cop bullshit on the mechanics.
particularly sad that oil costs so much in a country rich in crude.
Yet a tank of gas costs 1 cent
I've seen engines like that that had regular maintenance, often there is a history of overheating (cooling system issues) that accelerates the oil breaking down.
Is not the local oil, local oil is cheap, motorcraft is imported so it is very expensive, is you wanted 5-20W is the only way. And the problem is not the oil being expensive, is the wages being ridiculous.
I realize that the refine product is not the same as the local stuff.
I didn't realize how low the wages were.
The official exchange rate versus the real exchange rate is causing crazy import/export shenanigans. It is why there are toilet paper shortages.
Good Lito, I hope things get better.
