3v mustang boost options
jacobkerner
I have a 2006 3v. I’m wondering what the cheapest supercharger/turbo kit is. I’m willing to install myself, and I don’t need to be making 500 hp, I’d settle for almost anything over 400 if it is cost effective. I’ve already looked into going fbo and n/a but now I want to see my options for boost. Don’t really have a budget, just as cheap as possible
MrAwesome987
Upstate SC
Your cheapest option is probably going to be someone's take off M90 setup. Next to that, pretty much any option is going to cost around 5k+.
MrBhp
If the On3 turbo kits are available, that would get you there. Base kit is $1950. Supporting mods could cost another 1k. If you go that route, or any route producing decent numbers, you should upgrade the fuel system. S&H on this forum has a top notch set up. @JeremyH
moved... not tech here. please read the posting rules
what's that saying... you can have cheap, good, and reliable... just not all at the same time...
FBO and N/A with stock heads/cams/intake manifold will get you as far as ~330rwhp.
Over 400rwhp definitely requires forced induction but when it comes to power adders, cheap and reliable don't go in the same sentence. Since cost effectiveness is what you're looking for, I'd suggest the Department of Boost GT450 kit:
https://www.departmentofboost.com/product/450-450hp/
DieHarder
Contact Jason at DOB. When folks upgrade he sometimes ends up buying back some of the early model manifolds and supporting parts. They're still good and you may be able to cut a deal for significantly less than he retails new kits for. Straight forward/easy install. I took my time over a week and very impressed with fit, finish and reliability. Then you'll want a tune by Lito.
MrAwesome987
Upstate SC
What DieHarder suggested is a good idea, but I bet you'll still end up around 5k all said and done for a DOB setup. Fyi.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
How good is your mechanical ability? Used kits pop up on buy & sell sites but often require a bit more skill than an out of the box kit.
A non intercooled vortech kit starts at around $4K and if you are resourceful, you can put together a fuel system, get a used tuner and be up and running for another 1K. A water/meth kit can get your charge temps back in check-or spend a bit more on your fuel setup and run E85-if available in your area and run it without a charge cooler.
jacobkerner
I don’t have any experience doing turbos/superchargers but I do understand how they work and I’m fairly mechanically inclined, so I believe I could figure it out, especially with the help of some buddies if needed. But yeah I’ve looked into that a bit, thanks for the input
jdlatil
Twin Srew Driver
Dept of Boost kit is great set up and price not bad.
eighty6gt
what is an F150 5.0 swap going for these days? ~500 hp, nice and light.
jdlatil
Twin Srew Driver
Cheap don't always save you money
Dept of Boost has quality parts and one of the most popular set ups for non build 3V engines. I have never heard one issue with DOB set up.
Perhaps I should’ve said low price instead of cheap.
jdlatil
Twin Srew Driver
The DOB weak point on most builds is the accessory belt/tensioner, I would expect.
why would make this statement?
Have friends with this set up and have no issues with belt or tensioner if follow simple instructions and any use the Frankenstein tensioner with no issue.
Department of Boost has few different entry levels setup all the to 1400 hp set up. Good Engineering and customer service.
Don’t think you should expect issues with belt/tensioner, unless you have personal experience!
