GallopingFord
I'm Cam - Mr. Indecisive
Engine and Transmission SOLD to TurboX
4.6L 3V V8 Engine/Transmission/Harness Low Mileage
Motivated Seller
Looking to make that V6 sound like a V8?
Well, I am pulling the beautifully STOCK maintained engine from my 2009 Ford Mustang Bullitt. This engine was meticulously maintained. The engine never had any problems. Engine has right above 23,000 miles. It has always been serviced properly with Ford Motorcraft synthetic oil at proper intervals. Engine was never supercharged, turbocharged, tuned on e85, fueled with tears of sweatshop workers, or disassembled. Stock plugs, injectors, coils.
The most modified the engine was –
Kooks LT Headers with Catted X Pipe
FRPP Hot Rod Cams
FRPP Intake Manifold
FRPP 62mm TB
JLT 110mm CAI
Corsa Sport Axlebacks #14311
Car made 353rwhp/325rwtq and pulled like a [insert innuendo here]
I will be including all the shiznit with the engine including the manifold, tb, intake, ecu, engine harness, k-member too with A-arms. I will not be including the body harness or the dash cluster. Let me make that clear – I will not be including, selling, or try to be convinced to sell my stock Bullitt gauge cluster.
Included:
-4.6L 3V V8 SOHC
-TR-3650 5-Speed Manual Transmission
-K Member with Stock A-Arms
-Stock Drive Shaft and Stock Shifter (stock shifter is crap and I would suggest upgrading immediately)
-ECU and Engine Harness
-Everything from manifold, tb, to intake
-Clutch/Flywheel
-that ought to cover it.
Items not included - Starter and one of the manifold 02 sensors
I am not responsible for you trying to put this into your sixxer and helping you complete the project. I will give you my advice and input on stuff, but I honestly cannot assist you with every small intricate detail. I’m honestly not a very smart person… ask JeffK.
The engine will be pulled out at my shop. I will take it out of my car using a putty knife and phillips screw driver.
1.I can freight ship it at your own cost, I’ll just get a pallet and load the sucker on it and we will go over the details of how much it will cost.
2.Pick it up with your own vehicle. AS A BONUS! I will physically do oil and filter change on your truck, rotate the tires for you and install a new air freshener fo’ FREE. (GM and Dodge products are void from this offer). Just kidding (not really). If you ask me if this will fit in your Mustang, I will cut you.
3.I will deliver this to your front door with my Ferd-F-10 thousand. I will deliver up to 300-400 miles. I will charge you for just fuel. When I arrive, you will need to figure out how to remove this from my bed. No you cannot just carry this thing by yourself unless you are Hercules. If you are a Greek god, I’ll shit a brick, and give you this engine for free.
FINAL and foremost, let me get to the price.
PRICE: $3,100 + Fees + whatever you decide from my slew of delivery options. Payment is only accepted in CASH or PAYPAL. Do not ask me if I accept monopoly money, because again I will probably cut you.
Shift knob NOT included.
Motivated Seller
FRPP Hot Rod Cams
FRPP 62mm TB
JLT 110mm CAI
Included:
-4.6L 3V V8 SOHC
-Clutch/Flywheel
